CK20S HST
   / CK20S HST #51
Fresh cut lawn with DMM60 mid-mount deck pictures
   / CK20S HST #52
Beautiful lawn and nice pictures!
   / CK20S HST
What kind of grass is that??? The grass looks awesome!!!!
   / CK20S HST #54
It's the stuff my builder installed when he installed the lawn about 8 years ago. He used a blend from a local "Lesco" distribution center thats a mixture of fescue, perennial rye, kentucky blue grass, and a healthy amount of annual rye to get it started.
I use a local company "Turf Technologies" who does a crab grass treatment in the spring and 6 treatments throughout summer along w/ grub treatment and lime in the fall. They also treated it for a sod webworm insect.
I also have a sprinkler system and that helps quite a bit when things get dry around here.
Just need to change blades and sharpen the other set on the deck -- and change the gear oil in the mower desk transmission and I'll be good for next season. Need to get an impact wrench for blade changes as I like to sharpen often as that helps to cut the grass instead of ripping it which helps prevent it from going brown after cutting.
Very happy w/ my CK-20 "residential lawnmower".
   / CK20S HST #55
I've got a bx24 (traded up from a crafstman) and I've been happy with the lawn mowing capability for sure. My BX24 seems a little light for the dirt work I'm now getting into. I'm exploring trading up to a Kioti CK25 or higher and then getting either a BX1850 or another craftsman (believe it or not) to just cut the 2 acres of mildly hilly grass around the house. Just MHO.
   / CK20S HST
If your planning on getting a BX for just cutting grass, don't do it!! Get a ZERO TURN mower.
UNUSED MOWER KING SSAB72-72" HYD ANGLE BROOM (A51248)
UNUSED MOWER KING...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
Two Post Car Lift (A50120)
Two Post Car Lift...
1988 BASSTRACKER 20' PONTOON BOAT (A51247)
1988 BASSTRACKER...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
