#11 (permalink) | |
Elite Member
Quote:
#12 (permalink) |
I have the CK20HST I don't think I could lift a round bale with the FEL. A couple weeks ago my son broke a tie rod on my 02 grizzly which weighs a little over 600lbs. I thought put the forks on and carry it to the barn, the 20 would not pick it up. Going on what you've said I would go with the 30. As stated this tractor is beefy. Hope this helps.
__________________
Mitch Hall Live in Big Blue Country (GO CATS) My toy: 2006 CK20HST, FEL, Rears loaded, 4'BB, 4' cutter, bunches of suff I made. |
#13 (permalink) | |
Elite Member
Quote:
#14 (permalink) |
The biggest problem with forks, bale spears and the like, is that they put the load a good ways away from the pivot pins.
This severely limits what you can lift. Especially when you figure a QA/Fork or Spear set-up can weigh between 100 and 300 more than the plain bucket non/QA set-up. I have seen 600lb bales lifted with a CK20, it was using a bolt on bale spear. Remove bucket add spear. CK25-35 should lift the same amount reliably with the same set-up possibly a little more. DK35/KL351 will handle 1000lb bales on a spear. The DK40/45 with 401 will handle them with authority! We have lifted off a crated 2485 BH with a DK35/KL351 combo using a set of heavy 48" WR Long Forks. With a QA spear it shouldn't have any problem with the 1000lb bales. BTI
__________________
**EARTH FIRST----We'll Clear-cut the other planets LATER** *******The poster formerly known as Kiohio****** 740-753-9242 |
#15 (permalink) | |
Quote:
#18 (permalink) |
Elite Member
Just note, that Mark.R is lifting directly below the pivot point and very close to the machine. If you put that bale on a spear, it would be a huge load for the tractor. Just like lifting anything yourself, the further away it is from the machine the less lift capacity is will have.. it drops fast, a good 30% for every 18". In round numbers, a CK20 has a published lift capacity over just over 1000lbs at the pins, about 650 in the bucket, and probably around 200lbs 3-4 feet in front of the loader where a bale would be centered. Don't think that it will lift the 1000+lbs that it says in the brochure.
#19 (permalink) | |
Quote:
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
