I have a dilema that I have discussed somewhat in a previous thread.
My main tasks are moving large landscape items using a combination of Dirt Works tree shovel and backhoe. My land has some pretty good slopes up to around 20% grade. After having tried a wheeled Bobcat and a few track loaders, I decided to go with a TLB and I still believe this is the best type of machine for my application.
About a month ago I bought my first tractor a CK30HST with a Woods LC102 FEL and BH80X backhoe. I had the rears and fronts filled for more stability. They appear to be very full since when I push the valve a bit with the wheel at the 12 o'clock position fluid comes out. I have been leaving the backhoe on because I go back and forth between the tree shoval and the backhoe quite a bit. This gives me a total weight of ~6000 lbs.
The tree shoval is best operated using a combination of FEL lift/curl and tractor power pusing the shovel into the soil underneath the tree/shrub. The weight is a good thing. However, the CK30 seems underpowered. With the tractor in low range when operating the tree shovel it is easy to bogg the engine down as I am digging under a tree. I also noticed that getting back up some of my slopes requires low range. I cannot do anything in high range except go down a slope.
After almost 20 hours on the machine I can say that I like it, but clearly there are situations where it is "engine power" limited. The CK35(34 HP) has 13.3% more horsepower. Would this make a noticeable difference? The difference in cost is about $1200. Is this worth pursuing with my dealer or am I expecting too much out this class of tractor? I haven't approached my dealer with this yet, but I am guessing if I am going to upgrade now is the time to do it before I rack up a bunch of hours.
A few more points:
I know I am operating the HST correctly (just lightly pushing the pedal).
I need the CK's manurverability so I cannot go to a bigger chassis.
when I remove the backhoe(~1000 lbs) I can spin the tires, but I have not been able to with the backhoe on.
As an interesting data point the kubota L35 weighs in around 6700 lbs and of course is driven by a 35 HP engine but has GST transmission. This was replaced by the L39 (same weight).
All input appreciated.
Thanks,
A few more points:
Thanks,
