Results 21 to 30 of 34
11-08-2011, 11:32 AM #21Super Star Member
- Join Date
- Sep 2005
- Posts
- 11,440
- Location
- Prudence Island, RI
- Tractor
- 2007 Kioti DK40se HST, Woods BH
Re: DS4110HS or DK40SE or even a Massey 1643
I think you are being generous in your estimates. The seat for example (I believe I was the one who quoted $500) that "upgrade" price was based on a false assumption that the DS seat was not comfortable. We have several posts from users and a dealer who state it is as comfortable as the DK seat.
Some of the other "upgrades" such as tilt wheel and automatic position on the PTO switch are hard to value as they cannot be purchased aftermarket. If you really need them you need a DK but if you don't then why bother even pricing them out.
Based on your estimates for upgrades, I would imagine, having lived with a DK for four plus years, that I would probably invest about $1000 maybe less to pimp a DS up to DK. Not much more. I'd do the telescopic 3PT links, a couple of rear remotes (probably $600 while an extra for the DK would be about $350). I'd skip the 3pt crank adjustment and just go to a hydraulic top and tilt. That would cost the same as to add it to a DK40 so I wouldn't add that dollar amount. Same for a top canopy, I'd add it to both tractors.
The only downside to the DS that I can really see is if HST is a priority. That is a non starter if you need HST but I cannot imagine that 8x8 is so much less flexible than 12x12 and the other features are things most people can live without if they are trying to maximize the bang for the buck in work capability rather than just wanting a fancy new tractor.
11-08-2011, 11:43 AM #22
Gotta IslandTractor, points well taken.
11-08-2011, 07:27 PM #23Gold Member
- Join Date
- Jan 2011
- Posts
- 290
- Location
- Queensland Australia
- Tractor
- Kioti DS4510HS , Kubota B7100
I have an 8x8 transmission and, for my needs, have yet to go pass low range 4th gear. The tractor is not licensed for public roads where the high range would be important.
Don't forget to factor in that tool box.
There have been a lot of posts from Kioti owners wanting to fabricate a replacement to the plastic one that, I understand, is on some other models.
11-08-2011, 07:32 PM #24Elite Member
- Join Date
- Feb 2002
- Posts
- 3,369
- Location
- western,pa.
- Tractor
- John Deere 850/Kioti DK 35 with top and tilt, kl1450 fel with quick detach bucket
11-08-2011, 11:34 PM #25Super Star Member
- Join Date
- Sep 2005
- Posts
- 11,440
- Location
- Tractor
Freudian slip there Vince. Constant mess??
Synchronized tranny would be a plus I agree. However, an awful lot of tractors have run perfectly well without them. Again, some folks will want HST too but it still seems that the 8x8 manual non syncho tranny would satisfy a lot of users.
11-08-2011, 11:39 PM #26Super Star Member
- Join Date
- Sep 2005
- Posts
- 11,440
- Location
- Tractor
I took your advice. I removed the wimpy toolbox from my DK40se and am going to fabricate a larger replacement. The original is steel but only about 16 inches by 5 by 5. Not much room for anything but a few wrenches and pins. Lots of empty unused space on the rear mount area so I am going to weld up a 24x7x8 replacement. I do like the basic construction of the factory toolbox so I will copy it. I may also try to work in some sort of chain storage behind the rear seat.
11-09-2011, 12:24 PM #27
Oh come on now, now I have to add a toolbox to think about, geez
Wont make it to the dealer today... Friday next chance I have, hope he will be open on the holiday.
11-11-2011, 04:37 PM #28
Ok guys, came back from the dealer and this what I have for exact numbers.
DS4110HS... $17,800
DS4510HS... $19,250
DK40SE 12x12... $25,400
DK45SE 12x12... $27,440
All I have to say is WOW on the price difference on the DS and DK, it goes without saying there is no way I would go for the DK over the DS for those prices. The DK45 was $100 more then the price of the Massey 1643.
So with all said, if I go with Kioti it has to be the DS, just trying now to see if it is worth the extra $1,450 for only 4 more extra HP with everything else being the same.
Then I have a extra problem given to me, he just had to show me 2 used Masseys...
1st was a 2007 451 with 500hrs, 2 remotes, Shuttle trans, FEL, 60" bucket AND grapple, he wants $15,000 serviced and delivered. Its not to clean but its all there, the owner used it for tree clearing (business).
2nd was a 2007 573 repo with 1,100hrs 2 remotes, sunshade, everything else seem to be std, he wants $15,000 and would add a New Bush Hog FEL with Skid-steer "66 bucket serviced and delivered for about $21,000. The tractors life was pulling a round bale, looks like it was taken care of better then the 451.
I know the 2 used tractors have nothing to do with the Kioti, but being that I was thinking of making money with what ever tractor I get, well they both seem to fit in my search.
I added pics of the used Masseys just so you give them a look, being this is the kioti forums maybe most really don't care to hear about the Masseys, just thought I would share... I am going to give them a post over at the Massey section to see what they have to say about them.Last edited by MrSteve; 11-11-2011 at 05:00 PM.
11-11-2011, 07:39 PM #29Platinum Member
- Join Date
- May 2011
- Posts
- 697
- Location
- Trent Hills, ON
- Tractor
- Kioti DK40SE HST
Is it common to use a 2wd farm tractor to clear land for a business down there? It looks pretty good in the picture but it got to have taken some abuse!
I guess if you can get away with a 2wd in your area then you might as well save some money.2011 DK40SE HST
11-11-2011, 08:23 PM #30
Similar Threads
DK40SE or GL3940
By gavinfred1 in forum Kioti Buying/PricingReplies: 9Last Post: 07-20-2011, 02:43 PM -
MF 1643, Kioti dk40se, JD 4120 & Kubota MX5100
By dlmpsy in forum Buying/Pricing/ComparisonsReplies: 32Last Post: 02-20-2011, 03:56 PM -
Workshop Manual for DK40SE
By kattywumpus in forum Kioti Owning/OperatingReplies: 9Last Post: 09-01-2010, 09:08 PM -
Price Check DK40SE TLB IS THIS COMPARABLE.
By dunked1 in forum Kioti Buying/PricingReplies: 5Last Post: 03-20-2010, 08:53 AM -
Hydraulics and lift capacity DK40SE vs DK45S/DK55S?
By swampjohn in forum Kioti Buying/PricingReplies: 6Last Post: 08-26-2008, 09:49 PM
