Page 4 of 8 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 80
  1. #31
    Member
    Join Date
    Mar 2013
    Posts
    43
    Default Re: kioti ck35hst sizing
    Quote Originally Posted by MtnViewRanch View Post
    I don't wish to cause problems here, so take this for the that it might be worth. Do yourself a favor and order a DK40 HST and be done with it. Don't forget to get both rear remotes and be sure to spec out that you want AT LEAST one of them with the float function.
    Good luck.
    Explain to me the need for more than 1 remote. And what is this talk of a float function?
  2. #32
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Quote Originally Posted by tedhrs View Post
    I use 1 remote for grapple and the other for hydraulic top link. I was told Kioti's remotes do not have a float option.
    Murph
  3. #33
    Member
    Join Date
    Mar 2013
    Posts
    43
    Quote Originally Posted by murphy1244 View Post
    I was gonna go with just the 1 to start. I was thinking of using it for the grapple as well....as i see it, if the tractor has an extra set of with the valve already in place, why spend the $800 for the electric one.
    How do you like the setup using this valve for the grapple? Did you have to do any mods to make it work?
  4. #34
    Epic Contributor IslandTractor's Avatar
    Join Date
    Sep 2005
    Posts
    21,124
    Prudence Island, RI
    2007 Kioti DK40se HST, Woods BH
    Default
    I have 2 rear remotes and if I were using one for the grapple, I'd want at least one other for a hydraulic topping lift. If I were using a box blade regularly or maintaining a road, I'd want two extras for the topping lift and the tilt function.
    My DK has a separate diverter valve for the grapple but I was very happy using the rear remote on my CK20 to control the grapple. Indeed, truth be told, I preferred the remote to my current set up. No modifications needed. Just get the correct length of hose and fittings then rig it and zip tie everything into place. You can be grappling within twenty minutes of starting the project and it will take longer to get the fittings on the hoses than it will to route and secure the hoses from rear to grapple. Once you try it out you can decide whether to make more permanent mounting fittings. In three years with my CK doing a ton of grapple work, I never bothered to replace the zip ties. Zero problems.
  5. #35
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,411
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    Float is built into the joystick functions, on the DK-40se/hst.
    I use a grapple and have both rear remotes to allow me to use the Top-N-Tilt for the box blade. I got them through Brian at Mtn. View Ranch. My setup includes a diverter valve which allows me to mount a momentary button on the joystick shaft to control open/close on the grapple, or left swing, right swing on my plow. It is the best of all worlds, IMHO. Best to get the second remote installed when you buy the tractor, if you see yourself using lots of implements - it will likely get you the best price point available.
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  6. #36
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,414
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    As has been explained, the 2nd rear remote can be used for a hydraulic side link, a VERY good thing if you do much grading at all, or for a grapple vs getting the diverter valve or true 3rd function. All personal preference.
    As far as the float function, I have heard that it is available on the DKs and we have seen it for a fact that it is available on the CKs. I can't imagine that you can get it on a CK and not a DK. There are several places where it sure is nice to have the float function on one of if not both of the top & tilt cylinders for the 3pt hitch.
    Attached Thumbnails Attached Thumbnails kioti ck35hst sizing-p1020048-jpg
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  7. #37
    Member
    Join Date
    Mar 2013
    Posts
    43
    Default
    As has been explained, the 2nd rear remote can be used for a hydraulic side link, a VERY good thing if you do much grading at all, or for a grapplje vs getting the diverter valve or true 3rd function. All personal preference.
    Wow...that's a heck of a valve back there. I don't have the need for that stuff. My 3 point work is mostly bush hog, round bale spear and a chain harrow drag for pastures and riding arena.
  8. #38
    Gold Member
    Join Date
    Sep 2011
    Posts
    422
    New Hampshire
    Kioti CK35 HST
    I paid $18,500 for the same deal on my CK35HST a year and a half ago back in October of 2011. I'm sure prices have gone up so it is in the ball park but maybe on the high side. Guess it depends on your area and how much prices have gone up during that time.
  9. #39
    Member
    Join Date
    Mar 2013
    Posts
    43
    Default
    I priced all of the tractors here all at the same size...well as close as I could get all spec'd closely...all hydro drives, 4x4, etc...
    kubota L3940 - $30500
    John Deere 3720 - $31500
    Massey 1640 - $28500
    LS R4041 - $23400
    NH boomer 40 - 26500
    Bobcat CT 440 - $24000
    Kioti DK40SE just - $21800
    Just comparing for prices here....this was discounts and dealer incentive pricing, so really the price I would be paying.
  10. #40
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Well sounds like Kioti Dk 40. Cant believe its 9k cheaper than the kubota.
    Murph
Similar Threads
  1. Kubota l3800hst or Kioti ck35hst?
    By Vanislander in forum Buying/Pricing/Comparisons
    Last Post: 11-13-2012, 01:10 PM
  2. new member bought ck35hst
    By copefarms in forum Kioti Buying/Pricing
    Last Post: 02-22-2012, 10:23 PM
  3. new ck35hst
    By delgra in forum Kioti Owning/Operating
    Last Post: 07-12-2011, 09:59 AM
  4. CK35 vs CK35HST
    By YANKEEDOWNUNDER in forum Kioti Owning/Operating
    Last Post: 05-18-2011, 03:22 PM
  5. KIOTI CK35HST WITH FEL =ADVICE PLEASE
    By JITA in forum Kioti Buying/Pricing
    Last Post: 06-02-2010, 04:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
