MinnesotaEric
Super Member
I got sidetracked by a neighbor who popped in just as I came out to fiddle with the tractor this afternoon, and so I did not get as much done as I had planned. Notwithstanding, I did get some things done.
The only way to make two extra line connections fit is to assemble everything on the bench and then feed the lines in.
With everything assembled, it is a tight fit. Even so, I may change the bracket design for the third time if I cannot get the softlines routed to the loader correctly.
Something NX series owners should take note of: while wiring in the 3rd fuction connections, I popped out a bolt that was holding an existing ground connection on top of the transmission housing directly under the seat. 6 months old and look at the electrolytic corrosion on this bolt. I cleaned this up and greased it and earlier I noted corrosion on the starter contacts. I think I'll add a sacrificial anode to limit this nonsense.
And I made a short video of the all-important blinking lights.
