#1 (permalink) |
My new LB1914 has a FEL. It is identified as KL102, Serial#SL20369.
I'm looking for the specs on this loader. I discover from the Kioti literature and website no info for this loader. Both the website and info sheet show that the loader for this tractor is the KL1210, are they the same? I need your help and advice! Thanks. |
#2 (permalink) |
The KL102 was the original loader number when the loader was manufactured by someone else. I don't have the specs, but I'm looking for you. Maybe someone else has one and can provide the specs for you. Other than that, contact customer_service@kiotitractor.com and ask for the specs. John
#3 (permalink) |
I can't find the specs, but you might be able to get them from a TBN member named HickoryDean. hickorycollins@hotmail.com
I don't know if he's still active in the forums or if this address is still valid, but he owns a 1914 with KL102 loader. John |
#4 (permalink) |
KL102 loader
Max lift hight-76" reach at max height-21" max dump angle-42 degrees reach with attachment on ground-52" rollback angle-23 degrees digging depth below grade-3" overall height in carry position-47" approximate weight/bucket-642# lift capacity @ pivot pins-630# breakout force@ ground level-1,050# relief valve setting-2,000 PSI rated flow-3.5 GPM |
#10 (permalink) |
That's cool you kept those flyers Vince. Sure came in handy for Tex. Many times it's hard to find out about a product that has changed. Some companies are savvy enough to have a link to older information, but most don't do it. John
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
