RexB
Gold Member
(I copied these posts from another thread, to separate my two questions)
My engine temperature sensor gauge on the dash has stopped registering engine heat. The connection is tight from the thermostat housing, so is there another place to look to fix it?
Yes it is helping I'm just slow to pick it up. On this '07 CK30HST, I'm looking at the right/rear engine head (looking from the drivers' seat) where the cluster of wiring and fuel lines is. (Not the exhaust collector tube side where I do see an engine hoist bracket but no wires are around it.) I'll have to look harder because I don't see the thick glow plug wire or the real coolant sensor wire going to the dash gauge. Could you point out in this picture which it is? If I'm even in the right location, it's a maze.
click 'n zoom
virgil said:your temperture sender / sensor for the guage is on the right / rear of the engine in the head.. it is vertical, close to the injector. a tight spot for big hands...
the sensor / sendor you spoke about at the thermostat goes to the timmer /relay circut for the glo-plugs. I learned this the hard way.. had a coustomer that the glow plugs would not work. relays, timers, switches and harnes was OK... it took me several hours to see it it was not plugged in at the thermostat !
RexB said:Thanks for the info on the engine coolant temp sensor...all my underhood connectors are plugged in. I was trying to avoid pulling the dash off to check if the connector on the guage has come loose. Have you worked on that too, or the glo-plug circuit only, if I was reading that right.
virgil said:please look closely at the wires (a big heavy glow, and a little temp) at the right rear of the head. There is a "bracket / eye" back there that the factory used to set the engine with. it is bolt on -12 mm if I remember right. I had one ck that the temp wire and glo plug wire was pinched against the firewall by this bracket. It took about 100 hrs of use before the wire shorted out.
If the wires look ok, then blame it on the temp sensor...part # E5205-32832.
I have had a few units with rat damage under the dash. it is real easy to remove the dash for an inspection. 10 mm deep set socket is all you will need.
hope this helps
click 'n zoom
