Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kioti > Kioti Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-01-2008, 06:30 AM   #1 (permalink)
New Member
Default kioti lb1914 lift capacity
what is the rear lift capacity for an LB1914 if I attach a 3 pt hay bail spear to the rear? should it be able to lift 500 lbs? what is the front loader capacity?
fyrman1 is offline   Reply With Quote
Old 05-01-2008, 09:24 PM   #2 (permalink)
Gold Member
Default Re: kioti lb1914 lift capacity
I am thinking 500 should be easy, if it is some inches behind the pivot. My B6000E kubota, little bitty machine can handle 700lbs.
Key will be how far back behind machine will the weight be that you are lifting. I have no experience with hay, just rocks, more rocks and more rocks. Come to think of it, want to buy some rocks???
Good luck,
Joel
__________________
Joel
2004 Kioti LK3054XS TLB
John Deere 350B Dozer with Six Way Blade
JoelD is offline   Reply With Quote
Old 05-02-2008, 12:33 AM   #3 (permalink)
driver444's Avatar
I looked on Tractordata.com, and it says you're rated for 1323 lbs. I would imagine that's at the lift eyes. So your lift capacity 24 inches behind the eyes would be around 925 lbs (70% of 1323). Another 24 inches behind that would be about 650lbs, (70% of 925). You shouldn't have any problem at all lifting a 500lb bale.
If by chance that lift capacity of 1323lbs is rated 24 inches behind the eyes, you have WAY more than enough capacity for a 500lb bale.
driver444 is offline   Reply With Quote
Old 06-02-2008, 02:41 PM   #4 (permalink)
gladehound's Avatar
I believe it is ~1300 pounds at 24 inches behind the eyes with using the holes closer to the eyes to connect the links to the lift arms and ~1000 at 24 inches using the near holes. With the first set up I mentioned you have less range of motion. I can confirm that mine will lift 12 rounds each over 100 pounds on a wooden platform on top of a carry all. That's proabably 1,300 - 1,500 at 20 inches back.
__________________
Ron
2004 Kioti LB1914 w/ FEL
gladehound is offline   Reply With Quote
Old 06-02-2008, 03:03 PM   #5 (permalink)
gladehound's Avatar
This isn't the load I was talking about but probably weighed as much.
__________________
Ron
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
