I spent a few hours on my LK3054 this weekend digging / pulling stumps and brush-hogging. When it was time to put everything up I noticed that fuel was leaking out around the fuel filter bowl. at leaste that is where I think it is comming from. I had a new fuel filter on hand so I decided to go ahead and change it out. I shut off the fuel valve, took the bowl off, and cleaned everything up pretty good... put the new filter on, filled the bowl with fuel and put it all back together, opened the shut off valve.
Now...I was looking at the owner's manuel about bleeding the air out of the fuel lines... so I find the blead valve and I try to open it up... It won't open.. I finally realize that is was allready open and had been since I got it!! I went ahead and cranked the engine a couple of time to make sure the air was out of the line. Then I closed the bleed valve and re-attatched the line to it. The eingine started up just fine after that... I let it run for a little while and it's all good.
So now... questions...
Is the bleed valve supposed to be open or closed while running?
If it is supposed to be closed, is there any harm in leaving it open?
Went out there to look at it again this morning and it's still leakign alittle bit of fuel. What should I check to stop the leak?
Thanks for any help on this!!
jb
jb
