#1 (permalink) |
Member
Hello,
Seems like a few folks are over-filling fluids while performing services on their tractors. Is there quite a bit of residual fluids remaining after pulling the plugs and filters? Are there any tricks for better draining? Like getting the tractor up to operating temp before service? Setting the implements in a certain position? Can you bump the engine starter to get better drainage? Thanks! CK 20 HST 50 hrs |
#2 (permalink) |
Elite Member
I wouldn't worrry about it. No one truly drains an engine of every last drop. It is not that there are toxins of some sort that will contaminate the new fluids. The new fluids/filters simply add more reserve lubricant capacity and filter changes just insure continued oil cleaning capacity.
#4 (permalink) |
Member
Got through what I think is the most difficult part of the 50 hour service... changing the transmission/hydraulic oil and filters and the engine oil and filter.
The only difficulty I had was trying to remove the engine oil filter. That thing must have been put on with an impact wrench. An oil filter wrench didn't even budge it. To get it off, I had to drive a large screwdriver through the filter with a hammer and then use all of the strength and body weight I could muster to get the thing to even start to move. It took me about 4 or 5 strained pulls to remove it. Not good for the old hemies, if you know what I mean. All other filters and plugs came off surprisingly easy. Glad I did it myself. The alternative was to schlep the tractor 60 miles to the nearest dealer. Yuk. Reading the discussions on DYI servicing really increased my knowledge base, taught me a few tricks and gave confidence. Thanks to all for your help. 06 CK20HST |
#5 (permalink) |
Gold Member
You are about the third or fourth person to say that about one of the filters being so tight.
I was apprehensive about it so I bought a filter wrench. I never needed it. Glade you made it through with no major problems. Don't forget to grease all the zerks. If the 20 is anything like the 30 there's a bunch of them!
__________________
Kioti CK30 HST - KL130 FEL + Toothbar - 84" Rhino LR500 RB - Woods RD6000 - Ford PHD |
#7 (permalink) |
Gold Member
Go through the manual a couple of times, seems like there's a million zerks, good thing, but easy to miss some. You've got courage removing the filter as you did, glad all is well that ends well. Happy motoring. Oh yeah, always clean the zerk with a rag prior to hooking up the grease gun.
__________________
Joel 2004 Kioti LK3054XS TLB John Deere 350B Dozer with Six Way Blade |
#8 (permalink) |
Member
Hi JoelD,
Just curious. How would you have removed a stuck oil filter? My filter wrench didn't budge it and I didn't have any large channel locks at hand. Anything else I could have done without puncturing the filter? I realize that you don't want to puncture the filter too close to the engine as you would damage the threads on the engine block. I would have definitely been up a creek if that happened. RE the zerks, good advice. I purchased a kit of spares, including some 90's, just in case. Thanks! Last edited by pooters; 05-18-2008 at 08:49 PM. |
#10 (permalink) |
Gold Member
I've always used the screwdriver/puncture method for the sticky filters too. In my experience if a filter wrench and ratchet (with a cheater bar) doesn't budge it the inner tube method probably won't either though it is similar to another suggestion. Strap wrenches.
I guess if the tube is strong enough that you won't destroy it while wrenching on it with the screwdriver it's identical to a strap wrhenc, eh? I still like the screwdriver through the filter method. Makes me feel more like a man and helps release some of the frustration created by the situation... ![]()
__________________
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
