#11 (permalink) | |
Gold Member
Quote:
#12 (permalink) | |
Quote:
stalling. We stopped using them years ago. |
#13 (permalink) | |
Gold Member
Quote:
Your picture-taker does a good job, keep the progress photos coming!
__________________
Kioti CK30HST, KL130b loader, KB2375 hoe, auger added bucket hooks, brush screen, TOPS, gallery |
#15 (permalink) |
Looking good. Just be careful that the bed bottom is perfectly level or you will have another premature failure as the "effulent" will build-up on one end. I am a firm beleiver that the Presby Enviro's are the best system out there for cost and size.
__________________
Derek Kioti CK20HST KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade Sims-Cab Depot heated cab Pics |
#16 (permalink) | |
Gold Member
Quote:
The plan is to level the base, set the pipes, and gently start placing the sand around the pipes. Oh what fun ! |
#17 (permalink) |
I'm still at a loss as to what you are calling a failure. To me a Presby system failure would be the units are holding, and not releasing, the water. If so the sand would not be saturated. I've seen my neighbor's leach field saturated on a couple of occasions. It's a rental property & the tennants didn't tell the landlord their toilet was running continuously until the field wouldn't take any more water. Both times it dried out in a few days. Are you simply flooding your system with more water than it can get rid of ? MikeD74T
#18 (permalink) |
Gold Member
The failure as it was explained to me.
The membrane surrounding the pipe and the first couple of inches of sand get plugged with a black Tar like substance. This does not allow the field to work correctly. Only recourse is to remove and replace... |
#19 (permalink) |
Gold Member
That's a heckuva' project you have going Bearhawk and mountains of materials, you aren't scrimping on it and good job! I empathize with your situation and add my best wishes that the field works as required when you're done, that's a job to be proud of.
__________________
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
