#1 (permalink) |
New Member
Hi:
Lets try this again...in the Kioti forum instead of Kubota. The ink on the deal for my new DK40SE rig wasn't even dry and my buddy was coming up with jobs. He is reshingling his roof and we wondered about using the FEL to lift the shingles to the roof. So he goes home and comes back with 13 feet to the roof, so the FEL isn't going to do it. What about the backhoe? It is speced at 136 inches reach from the pivot pin to ... where, and presumably the pivot pin is a foot or so off the ground. Is this likely to do it? Boulter |
#2 (permalink) |
Gold Member
I don't know the answer to the question, but personally, I'd order the shingles "roof loaded".
Or consider forks on the FEL, with a stand on it to get the other 4' or so.. Lifting them up with a BH might get interesting..
__________________
Please resize your pictures before uploading them. Try ImageResizer from Microsoft for free... Image Resizer Thereafter, just right-click an image and choose "resize". It's that easy! NE Oklahoma, ck30 kioti BH w/thumb, Broken FEL, toothbar, box blade. JD 60" brush hog. My Photo's |
#4 (permalink) | |
Gold Member
Quote:
__________________
Kioti DK40se with KL401 loader,Kubota RTV 900,Kubota 326 pro ZTR.Kioti 65 inch tiller. |
#5 (permalink) | |
Gold Member
Location: The real central PA everything else is philly or pittsburgh
Quote:
You may also want to think about getting a half a pallet load or so, if you will be at maximum reach for a prolonged time, with a box or whatever to get you to full roof height. You may also want to block up your fel if you will be there for awhile. A 4x6 should do ok for awhile. Some hydraulics leak down a little over time.
__________________
DK45 SE HST, wood RFM, Taylor box blade, Kioti FEL, Wood PHD65, toothbar, wood rear blade, need a rake, plow, canopy, and an addition on my pole building |
#6 (permalink) |
I didn't understand that almost all the shingles would have to be lifted at once. I assumed maybe 4 or 5 bundles at a time.Thats how Ive done it. Its sure better to get that little amount of lift to the edge of the roof. Might take a few trips but the savings are easily realized.
After doing roofing for several years, and lugging them up the ladder, I got a thought to 'copy' one of the ladder type shingle lifts. I made a 'sled' if you will that fit loosely over the rails of the ladder. Then with a HF small 12 volt winch , used it to pull the sled up the ladder.using a 12 volt battery
__________________
silenced1206 |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
