Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kioti > Kioti Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-05-2008, 12:01 PM   #41 (permalink)
Gold Member
Default Re: I think she is dead
agreed, this should be the dealer's problem and not yours.
Who is the dealer?
What has the district or corporate service rep had to say?
__________________
Joel
2004 Kioti LK3054XS TLB
John Deere 350B Dozer with Six Way Blade
JoelD is offline   Reply With Quote
Old 06-07-2008, 08:59 PM   #42 (permalink)
Since I was waiting for a solenoid. I decided to pull the old one off. I bumped it a few times hoping it was just sticking. I decided to bump the starter before I put it back on and the tractor fired up without the solenoid. Luckily it has a manual turn off at the pump, but if nothing else it proves it is the solenoid. I appreciate the help. Hopefully the solenoid is here Monday.
Limecuda is offline   Reply With Quote
Old 06-07-2008, 09:05 PM   #43 (permalink)
Is there any chance the solenoid was just stuck? If you put it back in does it work? I am assuming that it is not much of a job to R&R.
__________________
Jim
- Husky W4814- 48" walk behind lawn mower. For my 1.7 acres of lawn.
- '06 Kioti CK30 HST - KL130 loader w/reinforcing bracket, SS QA, LK3054 QA bucket, engine coolant heater, dual rear remotes, KB2375 Backhoe w/thumb, 7ft 6 way rear blade, chains front/rear, loaded rear tires, Kioti Canopy. For eveything else.
IXLR8 is offline   Reply With Quote
Old 06-07-2008, 10:11 PM   #44 (permalink)
No I played with it hoping to free it up but once reinstalled it once again refused to crank. Still aggravating to have to rely on the good folks at a message board versus the dealer.
Old 06-08-2008, 07:53 AM   #45 (permalink)
Gold Member
Is this tractor used for your business? My dealer has a policy[ different brand] of getting you a loaner,while your tractor is down. Normally a person couldn't afford to lose a weeks wages or rent a replacement machine. If part wasn't a warranty item you might get it faster from a bigger dealer online. If your dealer was really concerned,he would get you the solenoid off one of his tractors,replace it when your part comes in. Hope you make out fine. plowking
plowking is offline   Reply With Quote
Old 06-09-2008, 10:25 AM   #46 (permalink)
New Member
I don't know if it could be related, but I have an old MF 135 that recently had a starting problem. I told my son I thought the solenoid was bad, so he took it off and rebuilt it(he's a mechanic). He checked some other things, and told me to try it. It cranked, and ran good for a few days. This time he checked it himself, not listening to my suggestions. He told me I had a ground problem some where. I checked all the attachment points. I had a new ground cable for the nattery, so I decided to replace it. That fixed my problem. Even though it looked good, and continuity checked with a meter, the cable had some corrosion inside, and wasn't getting full contact at times. Hope this helps.
nogin007 is offline   Reply With Quote
Old 06-09-2008, 11:19 AM   #47 (permalink)
wallace's Avatar
If you want to continue to use your tractor you can remove the solenoid and cut the shaft off. put the solenoid back in and use the manual shut off on top of the pump like you did before.
__________________
Wallace Tractor and Equipment
www.wallacetractorandequipment.com
RICK WALLACE
(570) 689-7494
wallace is offline   Reply With Quote
Old 06-09-2008, 07:52 PM   #48 (permalink)
Gold Member
bearhawk's Avatar
If you are not sure if it is actually the solenoid, or the electrics that control it...
Hold off on ruining it unless you are sure...
bearhawk is offline   Reply With Quote
Old 06-11-2008, 10:30 PM   #49 (permalink)
Gold Member
DirtHauler's Avatar
Try checking the relay, It's on the firewall, right side. Above the Hydralic pump. Hold your finger on it and turn the key off/on, you will feel it "click" if it's good. (it's got the "orange" connector)
__________________
CK30 "gear drive", R4s; FEL w/toothbar; 60" RC; 66" Box Blade; Caroni TL 1500 & TM 1600 Flails; 66" CCM tiller; 14 & 16' IronEagle trailers.
DirtHauler is offline   Reply With Quote
Old 06-12-2008, 12:19 AM   #50 (permalink)
It is the solenoid. The dealer had to reorder another after getting the wrong one in. I modified the old one to get the tractor running while I wait for the new one.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
