Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Aug 2007
    Posts
    11
    Default KL-122 FEL on LK 3054
    The KL-122 won't pick the front tires off the ground. Is this a relief valve issue?
    Also, anyone know if the neutral port and PB port on the FEL control valve are one and the same ?
    Thanks Bob
  2. #2
    Veteran Member JoelD's Avatar
    Join Date
    Jan 2005
    Posts
    2,121
    Windham, NH and York, ME
    Kioti LK3054xs TLB, 2004
    Default Re: KL-122 FEL on LK 3054
    Can you post picture of the valve body?
    Joel
    2004 Kioti LK3054XS TLB
    Woods Box Blade
    King Cutter Tiller
    Three Point Snow Blower
    York rake
    60 inch king kutter tiller
    2000 Dodge Durango 5.9
  3. #3
    New Member
    Join Date
    Aug 2007
    Posts
    11
    Joel
    Attached is the valve with the line in question in red
    Thanks, Bob
    Attached Thumbnails Attached Thumbnails KL-122 FEL  on LK 3054-control-valve-jpg
  4. #4
    Gold Member kentrodngun's Avatar
    Join Date
    Jul 2005
    Posts
    431
    New York (Southern Tier)
    Kioti LK3054 & DitchWitch R40 Trencher/Backhoe
    Quote Originally Posted by bob2230 View Post
    Thanks Bob
    Bob, I've got the same machine & loader. I initially thought my FEL wouldn't lift the tires off the ground too, but on occasion the tires did lift up.
    Seems you have to invert the bucket (open section on the ground) then raise it up. Down pressure with the bucket in the normal position doesn't seem to raise the front end. Although my neighbor has a 1999 kubota L35 TLB and he CAN raise it quite easily in the "normal" position.
    I learn by my mistakes and I've learned a lot
  5. #5
    New Member
    Join Date
    Aug 2007
    Posts
    11
    Thanks, I'll try that.
    Any idea which port on the loader is the PB port. Nelson Long told me to connect the PB hose to the T port on his electric hydraulic valve kit and we think it's the one that goes to the neutral port on the tractor.
    Thanks again
    Bob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
