Results 1 to 5 of 5
  1. #1
    Gold Member o2batsea's Avatar
    Join Date
    Nov 2008
    Posts
    430
    Maryland
    Kioti DK45C 2005
    Default Cab roof removal
    One of the chores ahead of me is a small repair to the fiberglass portion of the cab roof which will require the roof's removal. Has anyone taken one off? Is thee anything specific that I should be aware of? It looks more or less straight up as far as taking it off goes.
  2. #2
    Veteran Member JoelD's Avatar
    Join Date
    Jan 2005
    Posts
    2,005
    Windham, NH
    Kioti LK3054xs TLB, 2004
    Default Re: Cab roof removal
    Would be super helpfull (to you) if you fill in your profile, include your location and in your signature include your machine type and any attachments and the like.
    For example I have no idea what is involved in removing your cab roof as I have no idea when type of machine or cab that you have.
    You'd be amazed at what these guys and gals will share if they have adequate information.
    Joel
    Joel
    2004 Kioti LK3054XS TLB
    Woods Box Blade
    York rake
    60 inch king kutter tiller
    - Kioti Hauler-less
  3. #3
    Join Date
    Nov 2008
    Posts
    430
    Maryland
    Kioti DK45C 2005
    OK I filled in my poop sheet, hope it helps others
  4. #4
    Bronze Member frenchie4x4's Avatar
    Join Date
    Dec 2006
    Posts
    88
    Pa.
    DK50c
    O2BATSEA, ITS QUITE SIMPLE THE ROOF OPENS LIKE A HOOD ON A CAR. UNSCREW A COUPLE OF BOLTS ON THE FRONT OF ROOF AND LIFT THE BACK IT'S HINGED. MINE ALSO HAS A PROP-ROD UNDER THE ROOF. IF YOU WANT THE WHOLE ROOF OFF ALSO UNBOLT AT THE HINGES. I HOPE THIS HRLPS FRENCHIE.
    Attached Thumbnails Attached Thumbnails Cab roof removal-grill-gaurd-install-008.jpg
  5. #5
    Join Date
    Nov 2008
    Posts
    430
    Maryland
    Kioti DK45C 2005
    Thanks for the pic. I went and looked in the repair book and found this very thing. RTFM!
    The repair book does take some creative interpretation...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
