Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Member
    Join Date
    Mar 2009
    Posts
    27
    Erie, PA
    Default Skid steer implements on a Kioti FEL with quick attach kit?
    If you put a quick attack conversion kit on Kioti FEL (or any other brand for that matter), could you attach and operate skid steer implements?
    Specifically I am looking to run a Harley rake and rock hound. I know they make these in a 3 pt hitch version but you can't rent them from the local skid steer rental place. I know the skid steers usually have front remotes to hook into so this could be the limiting factor on a tractor FEL.
  2. #2
    Approved Advertiser
    wallace's Avatar
    Join Date
    Feb 2004
    Posts
    2,953
    PA.
    MAHINDRA
    Default Re: Skid steer implements on a Kioti FEL with quick attach kit?
    You will not have enough hydraulic flow.
    You will also overheat your hydraulic system.
    I have a customer that is running a DK55 and we mounted a Rock-a-Way and he said he is very happy.
    We worked with Rock-a-Way to have a smaller gpm pump installed on the unit.
    Wallace Tractor and Equipment
    www.wallacetractorandequipment.com
    rwallacetractor@echoes.net
    RICK WALLACE
    (570) 689-7494
    We're not just a tractor store anymore!
  3. #3
    Elite Member
    Join Date
    Jul 2006
    Posts
    3,015
    midwest
    JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
    Wallace is right. Simple attachments with a cylinder or 2 won't be a problem. You don't have enough flow for most attachments that use any type of hydraulic motor. Many attachments with motors will require flow rates in the 16-22 gpm range.
  4. #4
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,914
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Also weight would be a major concern, Those rakes are way out front and HEAVY, especially the RockHound since it collects the debris vs. windrowing it off to the side like the Harley rake does.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  5. #5
    Gold Member
    Join Date
    Sep 2004
    Posts
    489
    Nashville, TN / Hickory, NC
    Kioti DK55C
    Yes,
    I think the weight is an issue. I nearly tipped my DK55 over a couple of times this week loading trash into a dump truck. The combination of not exactly level, high lift to get over the edge, a grapple attachment(more weight) and she almost went over, in fact not sure if it was before or after, it rolled the front tire off the rim.
    Here's a pic of my set-up.
    On the hydraulic front, I've noticed I either don't have the power or the pump is hot and not working to capacity, but the grapple at some points will not open as I am moving and/or articulating the bucket. Is it possible to go to / retrofit a higher capacity pump? I'd like to get a hydraulic post hole auger.
    Attached Thumbnails Attached Thumbnails Skid steer implements on a Kioti FEL with quick attach kit?-img_3893-jpg
    Nashville/Hickory
    Kioti DK55c(no longer for sale), Hustler SuperZ, 72 Box Blade, Stihl HT101, International Machines 7ft Mower, Liebherr 631B, RV7
  6. #6
    Epic Contributor IslandTractor's Avatar
    Join Date
    Sep 2005
    Posts
    21,115
    Prudence Island, RI
    2007 Kioti DK40se HST, Woods BH
    Quote Originally Posted by rvaitor View Post
    Something is wrong and it is not your pump capacity. It does not take much hydraulic flow to open and close a grapple. I could do it easily with my CK20. Obviously you have either a diverter valve or a third function valve so I would explore whether those are operating properly or blocked in some way rather than looking for a higher capacity pump.
  7. #7
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Yes,
    I would suggest, that if you want to use attachments on the front, you need more weight on the back. If you want more hydraulic power, use one of the PTO pumps below. I have a brother that lives in Hickory, NC, and I used to go their every summer in my younger days.
    Burden Sales Surplus Center Item Detail
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  8. #8
    Gold Member
    Join Date
    Sep 2004
    Posts
    489
    Kioti DK55C
    Thanks IT and JJ - I'll check both your suggestions out.
    I like the thought of a PTO pump to run a post hole digger(I like the reversing capability). I hadn't looked at them though - I guess you have an auxiliary tank as well.
    Hickory is nice, our farm is about 12 miles south off 18.
    Nashville/Hickory
  9. #9
    Join Date
    Jul 2003
    Posts
    12,914
    Westminster, MD
    There are HPD's designed for CUT's that have low flow requirements.
    KennyD
    www.boltonhooks.com
  10. #10
    Gold Member
    Join Date
    Sep 2004
    Posts
    489
    Kioti DK55C
    Quote Originally Posted by kennyd View Post
    Any experience with them?
    Nashville/Hickory
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
