Cracked hydraulic case
Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
  1. #1
    Silver Member George in Spokane's Avatar
    Join Date
    Jun 2006
    Posts
    109
    Default Cracked hydraulic case
    I came into the shed today and there was about a gallon of oil on the floor under the CK35 tractor.
    It is coming from a very slow (1 drop every 5 minutes) leak from a one inch hairline crack on the hydraulic case. It is just to the left of the bottom of the attachment point for the right 3pt arm.
    Did I back into something and crack it? The tractor is two years old.
    I assume it is owner error and it needs to be welded . I'm hoping that one of you will say JB Weld is an easy fix . What should I do?
    Thanks,
    George
    Attached Thumbnails Attached Thumbnails Cracked hydraulic case-img_3742-jpg   Cracked hydraulic case-img_3744-jpg
    2008 Kioti CK-35 w/ FEL, HST, toothbar, R1, RimGuard, 2" wheel spacers
    1956 Ferguson TO-35
  2. #2
    Member
    Join Date
    Nov 2008
    Posts
    42
    kawkawlin, mi
    jd 3520
    Default Re: Cracked hydraulic case
    I would not try and jb weld the crack. the structural strength has been compromised and either needs welding or replacing. AZnything on the 3 pt will continue to stress this spot.
  3. #3
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Quote Originally Posted by tbenn7362 View Post
    Yeah, and welding that will be trick since it's cast.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  4. #4
    Elite Member wdchyd's Avatar
    Join Date
    Apr 2010
    Posts
    2,886
    Hooksett, NH
    Kubota B2320
    Looks like a tender spot to weld.....it'll probably have to come apart anyway...
    at least getting parts shouldn't be a problem with a 2 yr old ( or new)tractor...
    2010 Kubota B2320 FEL & BH65
    If it ain't fixed don't broke it!
    http://www.tractorbynet.com/content/...-month-wdchyd/
  5. #5
    Gold Member
    Join Date
    Mar 2001
    Posts
    459
    Lake View,N.Y.(WNY)
    International 184(1980),KIOTI DK40(2002))
    George,I agree with the others however,you might want to try one of the places that do mechanical fixes.
    I have no personal experience with it but,my bro-in-law has told me that it is a procedure where they drill and stitch the crack with hardened set screws,and even warranty the work.
    You might want to check it out in your area before you spring for a new case...Mike.
    PS Have comfort in the fact that Kioti has the most reasonable tractor parts prices that I have ever seen.
    "If you get to thinkin' you're a person of some influence, try orderin' somebody else's dog around."
  6. #6
    Join Date
    Apr 2010
    Posts
    2,886
    Hooksett, NH
    Kubota B2320
    Quote Originally Posted by northcreek2624 View Post
    Yes, seen it done in an engine shop....they drill and tap crack spacing out screws close together, then grind them flush.....then keep drilling and tapping overlapping previous screws and so on.....then they peen the surface to match.....
    Don't know if they do it in a high stress areas but seen done when connecting rods come out the side of the block.....
  7. #7
    Join Date
    Jun 2006
    Posts
    109
    Thanks guys for the advice. Is it worth trying the JB Weld, i.e., will it create a problem for a welder?
    1956 Ferguson TO-35
  8. #8
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,842
    Murray, KY
    1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
    Look hard for another case but there are places that can fix anything right for a price. I have only seen this an AC D21 that was using a heavy 5 bottom reversing set of plows. Never heard the results.
    Look hard for another case. The labor is going to be a lot either way.
    I would want to know how it happened before going back to work with it.
  9. #9
    Gold Member
    Join Date
    Mar 2001
    Posts
    459
    Lake View,N.Y.(WNY)
    George,the only thing that you will accomplish with JB weld is to give a good laugh to the guys who will be doing the proper repair....Mike.
  10. #10
    Bronze Member frenchie4x4's Avatar
    Join Date
    Dec 2006
    Posts
    90
    Pa.
    DK50c
    George, Your tractor looks really clean and not abused. That area by the 3pt should be really strong for pulling implements possibly its a casting flaw. I have seen it on engine blocks and motorcycle cases. Your tractor is a 2008 2yrs old I was thinking warranty (defective casting) I would check with your dealer first before I'd try repairing. In 2008 didn't Kioti have a 3 or 4yr warranty? just my thoughts
    Frenchie
Similar Threads
  1. Non Branson (Napa/Wix) Hydraulic Filter Issues
    By SnowRidge in forum Century & Branson
    Last Post: 08-10-2016, 11:17 AM
  2. pre made 3/8 hydraulic hoses and adaptors
    By unitedhose in forum Build-It Yourself
    Last Post: 08-08-2010, 11:18 PM
  3. Oil & Fuel Case DX-40 pumped my engine FULL of hydraulic oil!
    By cpeters in forum New Holland Owning/Operating
    Last Post: 06-21-2008, 10:52 AM
  4. Case DX-40 pumped engine full of hydraulic oil !
    By cpeters in forum Hydraulics
    Last Post: 06-18-2008, 03:17 PM
  5. Hydraulic problems
    By EMail4U in forum Hydraulics
    Last Post: 10-02-2004, 08:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
