kattywumpus
Gold Member
I'm wondering what's involved to install Kioti's second set of rear remote? Can someone share the instructions with me? Thanks.
It involves removing the seat, removing the first remote valve, replacing the stacking studs with longer studs, stacking the 2nd valve first, then the first valve. You may need to replace the mounting plate at the rear of the tractor with the 4 hole plate, and running the pipes to the back.
All in all, a couple easy hours of work.
Here's some pictures from a while ago:
http://www.tractorbynet.com/forums/...00883-installing-ck30hst-remote-kit-pics.html
Mike
Finally got my rear remotes installed (thanks Rick). Get my Toplink tomorrow, will post pics when installed.
