PoorMansCat
Yep.. sounds like a cylinder head gasket or cracked cylinder head. Hate to hear that. The water pump won't typically push coolant like you are describing. The regulator hasn't had time to open but you are getting considerable pressure...
Another thing that is a flag is the white smoke that came out of the exhaust... probably some antifreeze that has accumulated in one or more cylinders and was burnt off when the engine was started.
