Loader Kioti & Polebarnzilla
   / Kioti & Polebarnzilla #1
MotorSeven
Elite Member
NE TENN (Hancock Co)
Kioti DK40SE Hydro
I am building 1/3 of a 80x50-ish pole barn w/loft. I scavenged some big utitilty poles, 28' long & 14-15" on the butt end. A neighbor came over with a 16" auger & dug 5 holes(my auger is only a 9"). I would love to say that I tilted up & set these monster poles with my DK40SE, but I have a neighbor that is a logger, so he came over and set them with his log truck boom....took about 45min & much safer.
I will trim the poles later when the other 2/3's gets built, but I do want to be able to stand up in the loft against the wall. The section I am building now is going to be the 80'x16' drop shed(in red to the right of the poles in pic #1) which will hold about 320 rolls of 4x4 hay. I am using the Kioti & forks to load logs on my sawmill, then off load the finished boards & beams. I'll post more pic's as it gets done.
I was straightening each pole and tamping the bases with a 'baccer stick.
   / Kioti & Polebarnzilla #2
That's HUGE. Sounds like a great project, and one that should keep you busy for the rest of hte year.
I'm confused by what it means that you are building 1/3 of the barn? Who is building the other 2/3's?
Eddie
   / Kioti & Polebarnzilla #3
What spacing are you putting the poles at?
   / Kioti & Polebarnzilla #4
A monster. Will your taxes go up?
Eddie, I am doing all of it...eventually. I went in halfsies with my neighbor on hay equipment. Neither one of us has enough barn/shed space to store the hay until we find a buyer. So, if you look at the first pic, for now I am only building the section in red off to the right of the main barn. Some call it a drop shed, & it will be 80' long, 16' wide. Later, after I get our house finished, I will set another row of big poles for th emain section of the barn, then do another 80x16' drop shed on the left side.
I haven't decided on how big(wide) to make the main section, I am thinking 20' so I have room to manuver a tractor inside easily. If I go 24' it also makes a good indoor riding area(and .22 gun range). I have learned the hard way...think BIG, or don't think at all!
Br, the poles are on 20' centers & there is 5 of them. Belive it or not finding the last 2 poles was very hard. I called every Utility Co between Bristol/Middlesboro(KY) & Knoxville....nada. I just happened upon a private company that has a contract to change out old/damaged poles & they give them away free.
The break in the winter weather the last couple of days has been great. I fired up the sawmill & milled some Poplar for the barn & a few cedar house logs.
RD
   / Kioti & Polebarnzilla #7
That is good to hear. I will follow with earnest! A great project and it will be a swell place to accumulate all sorts of good stuff!
   / Kioti & Polebarnzilla #8
20' OC ... tell me more. What are you using for your top plate? What about Rafters?
I have a Woodmizer mill, so I can cut up to a 28" diameter log & out to 26'(I made my own extension for the mill). Anyway, for the top plate and rafters it will most likely be Poplar & a 5 or 6x10" -ish.
   / Kioti & Polebarnzilla #10
WOW ... 5-6"x 10" ... You will set those on top of the poles? Thats a heavy heifer what you plan to lift it into place with ... Man, I am watching you !! keep some info coming our way ... as well more pictures.
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
2016 Dodge Ram 5500 4x4 Crew Cab Stellar 4421 4,000lb 2 Ton Crane Service Truck (A55973)
2016 Dodge Ram...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
MISC TIRES (A54757)
MISC TIRES (A54757)
Honda UTV (A56859)
Honda UTV (A56859)
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
