Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Aug 2006
    Posts
    86
    Default Front snow blade for a CK30
    Has anybody out there mounted a blade to the front of a CK30 for snow removal ? I was out last week using the back blade on mine and my neck is killing me from looking backward for 2 hours of plowing . If you have mounted one what did you do for angle adjust (Manual or hydraulic) and mounting (Quick change ?). It sure does seem it would be easier with the front blade than the rear mount.
  2. #2
    Join Date
    Feb 2004
    Posts
    960
    15 mi. N. of Winchester VA
    Kioti CK30HST, Kubota BX-1500,
    Default Re: Front snow blade for a CK30
    You are pushing backwards with your back blade I guess. I've used the ck30 and back blade going forward for several years and it works fine...
    Mike
  3. #3
    Gold Member
    Join Date
    Jan 2011
    Posts
    263
    IN
    Kioti CK30, JD X475. HPX Gator, Woodmizer LT10
    See Michigan Iron & Equipment.com for info. on frt. blades for Kioti's They are a Kioti dealer and manufacturer several attachments.
  4. #4
    Elite Member Dmace's Avatar
    Join Date
    Oct 2005
    Posts
    3,838
    Wakefield, NH
    Kioti CK20 HST
    I too would look at Michigan Iron and Equipment's site. If I had seen their front blades with hydraulic angle before I bought my rear mount snow blower I probably would have gone that route.
    Michigan Iron & Equipment: Kioti Dealer
    Derek
    Kioti CK20HST
    KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade
    Sims-Cab Depot heated cab
    Quote Originally Posted by DiamondPilot
    Now it's time for Ford and GM to step up
  5. #5
    Approved Advertiser
    BXpanded's Avatar
    Join Date
    Jul 2008
    Posts
    717
    Knoxville, TN
    Look here
    BXpanded Snowplow
  6. #6
    Silver Member JonKioti's Avatar
    Join Date
    Aug 2007
    Posts
    229
    Newfoundland, Canada
    CK-20S HST
    I have a Michigan Iron snow plow on my CK-20 and I love it. I opted for the subframe model which securely clips into place under the tractor after you remove the front loader frame. Transition takes about 10-15 minutes once you know what needs to clip where.
    Using the subframe, your loader joystick now raises and angles your snowblade. I push a 72" blade with no problem at all with mine; anything too much for it is handled with the snowblower I have on the back.
    The ability to maneuver around cars and put the snow just where I want it was well worth the cost plus freight to Eastern Canada combined.
    Jon
    Kioti CK-20S HST, KL-120P FEL, KB-2465 backhoe, 72" snowblade, pallet forks, Agrotrend 54" snowblower, 60" box blade, a barn to put it all in and a trailer to carry it all.
  7. #7
    Join Date
    Aug 2006
    Posts
    86
    Thanks for the links. I really like the frame mount on the MIE site, but the quick changeover of the FEL mount is nice too .
    Yes, I am going backwards. I can run forward with the back blade if the snow is too deep, but when we get a wet, heavy snow I have to run backwards or the tires ride up and I don't get a clean pass.
  8. #8
    Super Member
    Join Date
    Nov 2009
    Posts
    5,738
    Indiana
    Bobcat
    Quote Originally Posted by BXpanded View Post
    man that blade sticks out wayyyyyyyyyyyyyyyyy to far in fron of the tractor for my comfort level
  9. #9
    Join Date
    Nov 2009
    Posts
    181
    Southern Vermont
    Kioti CK 30 gear
    I found a used Meyer's 7.5 foot plow on Craigslist.
    The plow came mounted to a QA hitch. I had to replace one of the angle cylinders. I have a WR Long 4 in 1 bucket and the WR Long "extra" hydraulics on the loader arms.
    I run the plow hydraulics with the WR Long toggle. Works like a charm.
    Now if I can just get my wife to let me plow some snow.
    Marc
  10. #10
    Bronze Member harleyboy's Avatar
    Join Date
    Dec 2010
    Posts
    63
    alvinston ontario canada
    Kioti ck30hst
    I have a front blower on my 17hp kubota and does a good job but now i also have my CK30 HST and would like to use it, Im thinkin a box blade that quick tatches . I,m going to make my self. Anyone have one Size and pics would help.
Similar Threads
  1. Snow B3200 front snow blade
    By Gr333 in forum Kubota Owning/Operating
    Last Post: 07-18-2009, 12:35 PM
  2. Snow Snow Plow Loader Modification
    By TTTTTT in forum Chinese Tractors
    Last Post: 04-11-2009, 09:49 AM
  3. Snow Front Blade for Snow Removal??
    By CompShooter in forum Mahindra Owning/Operating
    Last Post: 12-11-2006, 09:15 PM
  4. Snow Front mounted blade for snow
    By jcmseven in forum John Deere Owning/Operating
    Last Post: 11-14-2005, 09:25 PM
  5. Snow BX2200 Front Blade or Rear for snow removal
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 12-12-2001, 01:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
