carhartt56
First of all , the three things that helped the most were the chain wrench for the hydralic filter , the big drip pan , and the fill jug that Holds one gallon for filling the hyd oil . I spent about 4.5 hours total and still need to check clutch and brake free play . Maybe one night this week ! I thought most drain plugs I removed where not very tight for my comfort . I had problems draining the front axle . left side drained quik , but right side was slow the hole way , and I never got the almost 2 gallons drained that should have been in the front axle .(half hour draining) I had the plugs open for venting and also rocked the tractor back and forth . Anyone else had this problem ? I also could not find the two grease fittings labeled (power steering cylinder) page 7-19 in owners maual . Have they been eliminated ?
Overall comments on the tractor at 50 hours are good , but I will wait for at least 100 hours and write a review. I will say the shifting has become smother and seems to have more power . With the new hyd. fluid ( shell Donax ) the brakes seem to be stronger also . Only flaw so far is the shuttle shift could be taller , a little hard to reach , but I am 6'1" . Thanks in advance !
Dk40SE SS
Dk40SE SS
