Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    New Member
    Join Date
    Mar 2004
    Posts
    17
    Stirling, Ontario
    Kioti DK45CHST
    Default DK 45se cab stereo
    Hello all,
    I'm wondering if anyone has upgraded the speakers in the DK cab? I wonder if maybe 6" speakers are possible without too much trouble. The stock speakers seem quite inadequate when the engine is running.
  2. #2
    Veteran Member Mousefield's Avatar
    Join Date
    Aug 2008
    Posts
    2,457
    Qualicum Beach on Vancouver Island, BC. Canada
    2008 CK35 HST
    Default Re: DK 45se cab stereo
    Quote Originally Posted by Markioti View Post
    Hello all,
    Don't have a cab but if I did would probably look at head phones.
  3. #3
    Join Date
    Mar 2009
    Posts
    156
    South/Central Arkansas
    DK45Se HST
    I can't help you since I still have the original speakers, but I'm curious to see what you find out because the speakers are as you described them......insufficient.
    DK45SE HST w/Cab, FEL, KB2485 BH, Markham 60" Grapple, 6' Disk, Woods Finish Mower, 6' box blade, 13Kw PTO Generator
  4. #4
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    5,217
    north idaho
    dk45se hst cab
    well, i personally dont mind the stock ones i have. I dont want to run them blasting so as to hear it over the reved tractor engine. I just like some background music. I can hear the sounds just great.
    You can prob replace them with a better grade of 4" speaker with 2 or 3 range built in, but the tractor noise would pretty much destroy the sound i would think.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  5. #5
    Join Date
    Jan 2011
    Posts
    5,217
    north idaho
    dk45se hst cab
    You can prob replace them with a better grade of speaker with 2 or 3 range built in, but the tractor noise would pretty much destroy the sound i would think.
    currently own
  6. #6
    Gold Member o2batsea's Avatar
    Join Date
    Nov 2008
    Posts
    430
    Maryland
    Kioti DK45C 2005
    Default
    I thought about upgrading the stereo, but the amount of hassle put that way low on the project list. I have some good headphones for my iPhone.
    Practicing the ancient oriental art of ren-ching.
  7. #7
    New Member
    Join Date
    Mar 2004
    Posts
    17
    Stirling, Ontario
    Kioti DK45CHST
    Thanks for the response. There is no headphone jack on the stereo so I'll do some checking and post anything I come up with as far as a speaker upgrade is concerned.
  8. #8
    Veteran Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    2,026
    texas
    kubota M7040 &m7040
    I been in stereos for awhile and installed my own in tractor,I dont believe you need to go up in size but go up in quality of sound equipment. A good name brand of speakers of same size will make a world of difference,but also how many watts your radio puts out to push the speakers matters also. Im not saying high dollar highends componets,but just run down to Wal-Mart get a sony/pioneer head-unit($100) and some 2way or 3way brand name speakers($60/80) or just start with speakers. Will say it only going to sound as good as your weakest link...
    As for replacing Radio,the wires are already there its just matching the colors and crimp cple buttsplices. You only have your main 3 wires(power,remote,ground),then the rest just speaker wirers.Just remember pull fuse before you start,lol!!!
  9. #9
    Join Date
    Jan 2011
    Posts
    5,217
    north idaho
    dk45se hst cab
    you do realize that there is an Ipod jack on the newer DK cab units... It located onder the right hand cup holder .. for some reason
    currently own
  10. #10
    Veteran Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    2,190
    Southern VT
    '10 Kioti DK 40se/hst
    I'd try Crutchfield, as but one example, for speakers/and or head units for your cab. There is something to be said for not blasting things too loud and not being able to hear when you might run over something, like a neighborhood cat or kid or what have you.
    I-pod and headphones sounds like a good idea, though unless its integrated to your system it becomes a stand alone source.
    Let us know what you find/decide to do.
    2010 DK-40se/hst, Kioti KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower, 72" Ratchet Rake. HLA Series 2000 7' snowplow, Aquiline MPC Rear chains. Diamondplate aluminum canopy. Fit Rite Top-N Tilt hydraulics.
    Scag Wildcat: Kawasaki 26HP.
    Bunch of STIHL chainsaws : 011, MS192T, MS200T, MS180C, MS230, MS270(Wood Boss), 038 Farmboss (1986 Anniversary edition).
Similar Threads
  1. Cab for B2920
    By gabrichter in forum Kubota Owning/Operating
    Last Post: 01-18-2012, 11:10 AM
  2. Kubota B3030HSDCC cab or John Deere 3720 cab? Please help!
    By FRIZ in forum Buying/Pricing/Comparisons
    Last Post: 07-16-2009, 04:03 PM
  3. 366 Frame Mounted blade
    By Nuru in forum John Deere Buying/Pricing
    Last Post: 10-12-2008, 10:47 PM
  4. 3000-20 cab upgrade
    By KennedyDiesel in forum John Deere Owning/Operating
    Last Post: 09-27-2007, 04:13 PM
  5. Kubota 3030 Factory Cab Stereo
    By mike@watervillegenealogy in forum Customization
    Last Post: 08-30-2007, 01:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
