Not yet, but it's on the list for this year.
Here's my plan: Get a big box, like refrigerator sized. Crawl under the tractor and take measurements, then transfer them to the cardboard and cut it to size. Use tape to hang the pattern from points on the frame where you are going to need attachment tabs. Once it is all in place, mark the locations of the tabs. Then take the cardboard and have a metal shop use it as a template to cut out the pan from a sheet of 4x8 steel. Then weld on the pre drilled tabs, bolt it on and go.
A sheet of steel here is around $100, so even if you paid labor of another $100, that's cheap insurance. My rad fan was $25 and a few hrs of frustration after a stick decided to de-blade it. My engine side shield got knocked off one day and pretzled, but I saved it buy bending it back into shape. Others have ripped off their filters and or mounts which are around a hundred bucks ea.
