Results 1 to 10 of 14
05-26-2012, 02:02 AM #1
CK25HST w/ JD 24T baler
Rebuilding a JD24T baler. Would like to run SLOWLY and STEADY on FLAT ground with my 2008 CK25HST (300 hrs).
Have done lots of reading. By the looks of it, I am only a little crazy.... BUT, not completely nuts as long as I do not push it (PTO @ 20hp, tractor weight w/ loader @ 3600lbs).
Your thoughts?
06-30-2012, 11:52 AM #2
Well, "they" said it couldn't be done... They were wrong! Test baled with the CK25HST... No rocking, and plenty of power on LOW gear.
I know... The real test will be on the field (later this week). Slow and steady..
06-30-2012, 11:59 AM #3
Re: CK25HST w/ JD 24T baler
Sraczi,
That is AWESOME!!! Congrats on the hard work and I hope it works flawlessly for you!!!
Pls post some action shots??!!
_____________________________________________
2010 Kioti DK40SE HST
401K FEL
Brush Bull 72, 6' disc, Homemade pallet forks
06-30-2012, 12:04 PM #4
Video coming next week. Big thanks to Zz for his numerous blogs & advice!
07-10-2012, 10:19 PM #5
20hp @ the PTO and weighs in at ~3700lbs. No real rocking action and baled 120 easy bales.
Not sure why so many posts don't advise this with smaller tractors - Kioti CK25HST handled it a-ok. Video soon to be posted on YouTube!
07-11-2012, 12:06 AM #6
Your drawbar/hitch looks a bit low. The implement tongue is usually designed to be level (horizontal). Is it because the drawbar has an offset in it and the hitch pin would hit the pto shaft?
I'd be concerned that the hitch would dig into theground if you hit a plow furrow or an animal hole. Keep the cutoff knives sharp, the hitch tight using a large enough pin and be wary of clumps in the windrows. Also check the needle stop springs to make sure they are clear of hay chaff, mud, and anything else that can get stuck in there. I use a leaf blower or air hose nozzle to clean the knotter bay after every use. That exposes any loose or weak parts to a watchful eye.
Fun, isn't it? If your baler has a wagon hitch, try attaching a small trailer or wagon onto the back. Good excuse to get Mom or the kids involved, especially if they benefit from the hay production.There is no "I" in team, but there is a "Me" if you want to jumble it up a bit...
07-11-2012, 03:45 AM #7Platinum Member
- Join Date
- Jun 2010
- Posts
- 851
- Location
- Annapolis Valley, Nova Scotia
- Tractor
- MF 135 Z134 Continental
Now that's impressive, whodda thunk it possible.
07-11-2012, 12:06 PM #8
Zz- Thanks for the great advice. Will look into it this weekend. Made sure the hitch pin was size-on-size but you're right, hitch did drag a bit.
Here's the YouTube video. The hay was haybined by my neighbor so I made 2 passes for each windrow. And yes, that is a mask (darn seasonal asthma ain't stopping me!).
http://www.youtube.com/watch?v=naJYC...e_gdata_player
07-11-2012, 04:39 PM #9Bronze Member
- Join Date
- Jan 2012
- Posts
- 86
- Location
- IN
- Tractor
- Kioti CK30, JD X475, JD TS Gator
did you rake the windrows or is that how the moco left it?
07-11-2012, 04:53 PM #10
My neighbor disc/haybined the field. The windrows were too wide for the baler so I had to make 2 passes. Next cut (hopefully), I'll sickle mow (MF 6') then probably 3-wheel rake (need to buy now) to a better windrow height/width.
The reason it took longer in the video for a bale is the 2nd pass had a tiny windrow.
Similar Threads
How to make JD 24t square baler tie tighter?
By jshwhite in forum Parts/RepairsReplies: 7Last Post: 05-15-2012, 09:59 PM -
JD 24t baler advice
By jshwhite in forum AttachmentsReplies: 4Last Post: 11-29-2011, 02:57 PM -
jd 24T baler
By 4590 in forum Ag Tractors & MachineryReplies: 11Last Post: 08-14-2011, 09:27 AM -
What's good for my 458 JD Baler
By Nelson Farms in forum John Deere Owning/OperatingReplies: 6Last Post: 08-30-2010, 11:03 PM -
JD 14T Baler Advice
By scesnick in forum AttachmentsReplies: 13Last Post: 03-28-2008, 09:42 PM
