Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Member
    Join Date
    Feb 2010
    Posts
    48
    Default Kioti parts...
    Hi Folks,
    Where is the best (cheapest) place to order good quality parts on-line for a Mechron? I prefer factroy parts.
    Thanks
  2. #2
    Silver Member DrRick's Avatar
    Join Date
    Mar 2006
    Posts
    187
    san angelo, texas
    dk55, jd 450,case 811b,kioti mechron,farmal cub & super c
    Default Re: Kioti parts...
    i have gotten them from my dealer but have not had to buy anything of consequince yet. What were you needing? Also i and my friend both noticed a bit of belt squeel this last weekend from our mechrons, and were a bit worried about that. I also saw the gator diesel for the military rated at 38 mph and it is a diesel with 2 speed much like ours. Wish mine went just a bit faster on a few occasions. I added a heater to mine last winter and it looks almost factory was about 250 bucks but went in fairly easy.
    rick
  3. #3
    Member
    Join Date
    Feb 2010
    Posts
    48
    Hi DrRick,
    I don't need much, a couple of oil filters, bed rails for the dump bed and the rear screen for the roll cage. I can get them from my dealer for $400 or so but I was thinking about down the road, when somethig big breaks, assuming that it will.
    My Mechron has proven to be very handy. I only have 13 acres and most of that is wooded but it was most helpful clearing trees after the hurricane we had last fall. We lost 4 big poplars, 1 maple and a sweet gum during that storm. The largest one went down and took the others out like dominoes. It cleared out a 200 yard path through the woods. Amazing! and t made a great shooting range. It took about 2 months to cut and split the wood but I have PLENTY of fire wood now. Too bad most of it is poplar.
    The Mechron seems to be bullet proof (knock on wood). I haven't had any problems since I fixed the dragging emergency brake when I took delievery and I seem to find a use for it nearly every day. I've only put 50 hours on it in the 6 months that I've had it. I'm very happy with it.
    I don't really have any opportunity to go any distance so the 25 mph that mine goes is plenty fast. I wish I had a large Nat'l Forset to run around in. That would be a blast and I could see a little more speed would be desirable there. The suspension on these things is great, lots of travel and a plush ride. As I said, Im very happy with mine.
    Let me know what you find out about your belt.
  4. #4
    Member yuccafarmer's Avatar
    Join Date
    Nov 2006
    Posts
    25
    Elbert County, CO
    Kioti DK40, Mechron 2200
    DrRick... Can you add some details about the heater you added? I've got 65 hrs. on my Mechron and it's running just fine. I had the dealer do an engine oil change when he fixed the differential vents. That factory mod resulted in a gear lube change. I haven't needed any other parts or service.
  5. #5
    Gold Member
    Join Date
    Sep 2011
    Posts
    395
    New Hampshire
    Kioti CK35 HST
    Quote Originally Posted by patcopaul View Post
    Hi Folks,
    Thanks
    Since you posted this question twice I'll post my response twice I don't think you can buy Kioti parts online. Well... you can always find a dealer online and have parts shipped to you but I don't know of a "web store" where you can buy parts. If you find one let me know
  6. #6
    Advertiser
    MichiganIron's Avatar
    Join Date
    May 2008
    Posts
    512
    Central Michigan
    Full line of KIOTI Tractors, BEFCO and Worksaver Implements
    Parts for all KIOTI equipment can be ordered on-line though our on-line parts cart.
    Michigan Iron and Equipment, LLC
    www.michironandequip.com
  7. #7
    Join Date
    Mar 2006
    Posts
    187
    san angelo, texas
    i bought a universal type heater and i place it under the dash with a piece of strap holding it up ( under the hood is where i supported it ) i will get some pics as soon as i get back to ranch . It really looks factory and works pretty well . I used the line to the cig lighter for power. It has a 2 speed fan and is not obtrusive to the middle seat passenger. It suggested a simple t fitting into the radiator hoses, however I placed a t at the engine bypass outlet in order to get faster warmup. The pics will explain much more clearly.
  8. #8
    Join Date
    Nov 2006
    Posts
    25
    Elbert County, CO
    Quote Originally Posted by DrRick View Post
    Thanks. Please include mfg. and where sold. Do you have the cab enclosed?
  9. #9
    Veteran Member coobie's Avatar
    Join Date
    Sep 2004
    Posts
    1,587
    S.Michigan
    Kubota RTV 900, JD 740,Kioti DK 40 with KL401 loader 2011 ford F250.
    Try your local dealer.coobie
    Kioti DK40se with KL401 loader,Kubota RTV 900,John deere X740,Kioti 73 inch tiller.Ingersoll 4020 3pt,troy bilt tiller,Billy goat brush cutter.
  10. #10
    Join Date
    Mar 2006
    Posts
    187
    san angelo, texas
    Quote Originally Posted by yuccafarmer View Post
    utv parts and accessories dot com, i purchased the universal heater for around 250.00. I have a few pis=cs but cannot figure out how to upload.
Similar Threads
  1. Kioti parts
    By greengrasshoper in forum Parts/Repairs
    Last Post: 06-12-2012, 02:23 AM
  2. Kioti Dealers and Parts
    By ritcheyvs in forum Kioti Owning/Operating
    Last Post: 11-12-2011, 07:57 AM
  3. Availability of Kioti parts
    By NorthernChilli in forum Kioti Owning/Operating
    Last Post: 10-03-2010, 11:09 PM
  4. Kioti Parts
    By MtnMan001 in forum Kioti Owning/Operating
    Last Post: 04-26-2010, 04:15 PM
  5. Will Bobcat Carry Kioti Parts
    By Pozzman in forum Bobcat Tractors
    Last Post: 08-12-2009, 06:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
