Results 1 to 10 of 20
07-09-2012, 09:01 PM #1Platinum Member
- Join Date
- Jun 2007
- Posts
- 622
- Location
- Central,Iowa
- Tractor
- Kioti DK45S
DK45S fuel tank removal
Anyone out there know the procedure for removing fuel tank on 2009-10 Kioti DK45S?
"The significant problems we face cannot be solved at the same level of thinking we were at when we created them."
Albert Einstein
A nation of sheep will beget a government of wolves. - Edward R. Murrow
"Being smart is not how much you know, it's knowing where to look."
R. James
07-09-2012, 11:37 PM #2
Re: DK45S fuel tank removal
Curious why you want to remove it?
2010 DK-40se/hst, Kioti KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower, 72" Ratchet Rake. HLA Series 2000 7' snowplow, Aquiline MPC Rear chains. Diamondplate aluminum canopy. Fit Rite Top-N Tilt hydraulics.
Scag Wildcat: Kawasaki 26HP.
Bunch of STIHL chainsaws
: 011, MS192T, MS200T, MS180C, MS230, MS270(Wood Boss), 038 Farmboss (1986 Anniversary edition).
07-10-2012, 04:43 PM #3Veteran Member
- Join Date
- Mar 2005
- Posts
- 1,323
- Location
- Erie, Pennsylvania
- Tractor
- Kioti CK30HST
If you search for posts about fuel tanks around 2 months ago, another member had to remove his because it rusted. It didn't seem complicated but was a pita getting things out of the way to get clearance to pull it out.
Vic
2004 Kioti CK30hst, KL130 fel, KB2375 bh
07-10-2012, 06:03 PM #4Platinum Member
- Join Date
- Jun 2007
- Posts
- 622
- Location
- Central,Iowa
- Tractor
- Kioti DK45S
I just figured I'd do it for the heck of it.............Not. It has developed a leak. It is plastic and it is a PITA. Everything seems to be out of the way, but still can't get it free. It is loose, I can move it all around, just doesn't seem to have clearance to get out.
Albert Einstein
R. James
07-10-2012, 06:05 PM #5Platinum Member
- Join Date
- Jun 2007
- Posts
- 622
- Location
- Central,Iowa
- Tractor
- Kioti DK45S
Yeah, I found that post and read it all and looked at pics, trouble is, pics show removal , but there is either no engine to deal with or no dash-don't remember right off hand.
Albert Einstein
R. James
07-10-2012, 10:31 PM #6Platinum Member
- Join Date
- Jun 2007
- Posts
- 622
- Location
- Central,Iowa
- Tractor
- Kioti DK45S
Albert Einstein
R. James
07-11-2012, 08:14 PM #7
OK, so now you've had your fun, now what to fix? Under warranty?
07-11-2012, 08:23 PM #8Platinum Member
- Join Date
- Jun 2007
- Posts
- 622
- Location
- Central,Iowa
- Tractor
- Kioti DK45S
J-B weld probably. Could plasti weld but don't know how thick rest of it is around there. At least with the JB weld, I can build it up a bit. I really do feel this is a faulty part issue, but 2 mos. past 2 year bumper to bumper. Hopefully dealer will rescue me. By the way, the relief for the fitting that is in the mount is still not big enough- so I guess Kioti didn't address this issue yet. With the hose on the fitting, I figure it was under constant vibration and the embossed area finally broke.
Albert Einstein
R. James
07-11-2012, 08:25 PM #9Super Member
- Join Date
- Nov 2011
- Posts
- 6,490
- Location
- Ohio
- Tractor
- Kioti DK 40-Massey ferguson 135-Simplicity Conquest
I think he's
Murph ------------ Sent from my HP laptop
Nothing runs like a Deere when being chased by a Kioti
07-11-2012, 09:50 PM #10Platinum Member
- Join Date
- Jun 2007
- Posts
- 622
- Location
- Central,Iowa
- Tractor
- Kioti DK45S
Yeh, actually 3 mos. past 2yr bumper to bumper, but hoping to get dealer to address from a safety standpoint. Sent him a PM, we'll see. I went through this a while back on a 92 thunderbird. Head gaskets at 72k. Faulty fire ring around cylinders. Ford had numerous problems and finally issued recall AFTER I had already fixed and sent down the road.
Albert Einstein
R. James
Similar Threads
Oil & Fuel Fuel Tank Removal HELP Please
By Arizona Rancher in forum Kioti Owning/OperatingReplies: 23Last Post: 01-30-2012, 09:36 PM -
580 B fuel tank removal
By wjpedersen in forum Parts/RepairsReplies: 1Last Post: 09-09-2007, 12:51 AM -
Fuel tank removal??
By MDSteve in forum Parts/RepairsReplies: 1Last Post: 05-15-2007, 03:07 PM -
Fuel oil tank removal
By jpr62902 in forum Rural LivingReplies: 8Last Post: 11-17-2003, 07:41 AM -
Oil Fuel Tank Removal
By Anonymous Poster in forum Rural LivingReplies: 15Last Post: 08-02-2001, 11:20 AM
