CK30 Injection Pump
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
  1. #21
    Member
    Join Date
    Aug 2012
    Posts
    26
    Mt. Cobb, PA
    2006 Kioti CK25
    Default Re: CK30 Injection Pump
    You got it....governor lever won't move until you start it and centrifical force takes over and moves it towards pin and pushes it to idle. If it was working properly and you turned key on and solenoid released...you would see that pin move all the way to governor tab then turn key to start and when it starts you will see the governor move the pin back to idle. When my first one went it was stuck exactley like yours in the off position. Teeth on gears in pump broke off and jammed it up.
  2. #22
    Join Date
    Jun 2012
    Posts
    61
    weston,wv
    kioti dk45s
    btward79,
    If you go to second page on kioti owing/operating and look at post titled Injector pump failure from bob42 on a DK40 you will see pictures of what my IP pump looks like. The broken teeth on the gears is exactly what mine look like also. Good luck with any response from kioti. the only thing i can get my dealer to say after three different stops( latest one this past friday) is it is because of fuel. This is nothing more than a bunch of nonsense and it is nothing more than a piece of junk made in KOrea that bosch and zexel will not support.
  3. #23
    Veteran Member ritcheyvs's Avatar
    Join Date
    Nov 2011
    Posts
    1,628
    Kittrell, NC
    Kioti DK45S
    Quote Originally Posted by btward79 View Post
    So the 1st lever close towards our view is the throttle? That doesn't appear to touch or be in any position to ever touch that pin on the rod in the pump... Now that 2nd lever hiding in the back there the govener I believe you're saying that still doesn't touch the pin on the rod but I can see how it could do that... Unfortunatly, that pin doesn't move at all.
    As for the tube piece I figured that's what you were referring too... I see another post here http://www.tractorbynet.com/forums/k...not-start.html
    mentioning to remove the stop solenoid... What is the dangers in removing this I see some words of caution...
    btward: Hopefully, this excerpt will explain how the linkages are intended to work:
    http://kittrellcommunitywatch.dyndns...IP%20operation
    The figure is confusing because it makes it look like the rack pin goes in the slot of the throttle lever, which is not the case as dlw has explained.
    Scott: Kioti DK45S, KL451 loader, Phoenix M72S mower, Deere BB5072 Box Scraper, Fit Rite Hydro Top & Side Links; DIY Kioti knowledge site (in work): http://kioti.dyndns.org/
  4. #24
    Join Date
    Jun 2012
    Posts
    76
    CA
    Kioti CK30
    Quote Originally Posted by sherrym View Post
    btward79,
    I've seen those pictures. Thanks! As Scott mentioned, the bottom of that whole IP pump is lubed by oil not Diesel. Have you mentioned that?
    Scott, Thanks for the link. I'm on board with that. Thanks to everyone for all of the help. At this point I'm waiting to see what the dealer can do. If nothing I'll try the other two in the general area. If Kioti won't own up to a 39hr tractor with an IP failure (not to mention broken tach needle, electric only has 2yr warrenty ) one month out of warrenty then I guess it shows what type of company they are. This is a pretty serious thing. And you can bet your bank account anyone reading these posts on the edge between buying a Kioti tractor or another brand, this will quickly make them go the other direction.
  5. #25
    Join Date
    Nov 2011
    Posts
    1,628
    Kittrell, NC
    Kioti DK45S
    Quote Originally Posted by ritcheyvs View Post
    As I understand it, the rack pin should be inside the slot of that lever and the spring acts on the lever which acts on the pin. ...
    Disregard my previous opinion/thought. dlw has actually been inside these things and I'm sure he's right.
    I was confused by an older version of the linkages. I now understand the IP rack is spring-loaded to the front so the forward position is established only by the stop on the governor lever (unless the stop solenoid or manual stop lever pushes the rack to the off position). The throttle lever (slotted one with spring) interacts directly with the governor lever (under front cover where you can't see it) to establish the position of the governor lever where it limits the forward travel of the rack pin.
  6. #26
    Join Date
    Jun 2012
    Posts
    61
    weston,wv
    kioti dk45s
    [QUOTE=btward79;2978000]I've seen those pictures. Thanks! As Scott mentioned, the bottom of that whole IP pump is lubed by oil not Diesel. Have you mentioned that?
    Scott, Thanks for the link. I'm on board with that. Thanks to everyone for all of the help. At this point I'm waiting to see what the dealer can do. If nothing I'll try the other two in the general area. If Kioti won't own up to a 39hr tractor with an IP failure (not to mention broken tach needle, electric only has 2yr warrenty ) one month out of warrenty then I guess it shows what tquitype of company they are. This is a pretty serious thing. And you can bet your bank account anyone reading these posts on the edge between buying a Kioti tractor or another brand, this will quickly make them go the other direction.[/QUOTE
    Maybe people in other countries dont mind spending 1000 to 1500 on this problem with only 20 to 500 or so hours before this part goes. I know I do and I am sure there are others in America that mind as well.
  7. #27
    Join Date
    Nov 2011
    Posts
    1,628
    Kittrell, NC
    Kioti DK45S
    This is a customer service issue more that a manufacturer issue. Anyone can make or buy a batch of bad parts. The real pros catch the problem early and fix them, including retrofits. In this case it looks like some bad parts slipped through the crack and got to customers; so now it's a customer service issue. We've heard plenty on TBN about how Kioti USA handles customer service (it's the dealer's problem, stone-wall the customer). And they previously fired a bunch of their dealers.
    It would be interesting to know if Bobcat works directly with Daedong or through Kioti USA. If the former, I might need a bucket of white paint.
  8. #28
    Join Date
    Jun 2012
    Posts
    76
    CA
    Kioti CK30
    I was searching through the forum over the weekend and someone had a name and number for someone who worked at Kioti head quarters. Anyone have that name and number? I sure wished I wrote it down when I saw it!
  9. #29
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Ron Parish,Chief Manufacturing Director 919-374-5100 Good Luck..
    Murph
  10. #30
    Join Date
    Jun 2012
    Posts
    76
    CA
    Kioti CK30
    Quote Originally Posted by murphy1244 View Post
    Now that's just outstanding! Thanks murphy1244! I think I'll wait until afternoon if I haven't heard back from my dealer before calling. I don't want to abuse it but this is apparently a big problem for the "pack".
Similar Threads
  1. Oil & Fuel injection pump
    By achallie in forum New Holland Owning/Operating
    Last Post: 06-13-2012, 07:05 PM
  2. injection pump
    By kandcjamieson in forum Massey Ferguson Owning/Operating
    Last Post: 06-01-2011, 01:56 PM
  3. injection pump
    By Woolmanr in forum John Deere Owning/Operating
    Last Post: 12-01-2010, 02:57 PM
  4. INJECTION PUMP
    By EDDIESGSR in forum Parts/Repairs
    Last Post: 05-08-2009, 04:17 PM
  5. Injection pump?
    By Richard in forum Parts/Repairs
    Last Post: 09-20-2008, 02:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
