Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. #21
    Gold Member GMtb42's Avatar
    Join Date
    Jun 2007
    Posts
    271
    Reno, Texas
    SOLD L2800DT-F, purchased Kioti CK20
    Default Re: CK20 cracked FEL
    In case anyone wonders what the kit looks like installed here it is (someone may have already done this) ;
    Attached Thumbnails Attached Thumbnails CK20 cracked FEL-1110121126.jpg   CK20 cracked FEL-1110121123.jpg
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    Gold Member mpham's Avatar
    Join Date
    Oct 2011
    Posts
    289
    Massachusetts
    Kioti ck20
    Default
    Thanks for the pic. I now know my 2008 hasn't been done.
    Phil. from Mass.
    2008 Kioti ck20 with 380 hours
    New to me 2011 K120 loader
  4. #23
    Super Star Member IslandTractor's Avatar
    Join Date
    Sep 2005
    Posts
    11,640
    Prudence Island, RI
    2007 Kioti DK40se HST, Woods BH
    Default
    Quote Originally Posted by mpham
    Your 2008 should have the KL120B loader which does not need the reinforcing kit. I believe all CK20 loaders built after 2007 (?2006) are the new style. Easy to check: if there is a tube connecting the two loader arms then it is the new style.
  5. #24
    Join Date
    Oct 2011
    Posts
    289
    Massachusetts
    Kioti ck20
    OK. Will check and see. Mine sold as a 2008 but has a 2006 serial number. I actually just purchased a complete 2011 ck120 loader unit used.
    Phil. from Mass.
  6. #25
    Join Date
    Feb 2010
    Posts
    137
    N. IL
    Kioti CK 27 shuttle
    I would be curious as to where I can look or if someone could tell me how to find out what year my ck27 is based on the serial number. you all seem to know and I must either be looking in the wrong place or just overlooking something simple.
    thanks
  7. #26
    Join Date
    Oct 2011
    Posts
    289
    Massachusetts
    Kioti ck20
    Quote Originally Posted by treman View Post
    thanks
    Check here:
    http://www.tractorbynet.com/forums/k...n-numbers.html
    Phil. from Mass.
  8. #27
    New Member
    Join Date
    Aug 2004
    Posts
    13
    maine
    KIOTI CK20 HST
    I've had the repair kit for quite a while and never got around to installing it. Finally opened the box today and there are no instructions in the box. Anyone have them available?
    Thanks ... John
  9. #28
    Join Date
    Jun 2007
    Posts
    271
    Reno, Texas
    John, I had no instructions here either, pretty simple goes on one way.
    I removed the pins on the bucket cylinders (toward bucket) and propped them up with a block of wood so as to get the large plate with the hose slots over the crossmember, I needed to clean out grease holes in pins anyways (might be able to go from underneath with FEL up in air without taking cylinders loose) Once I got the larger piece on I reattached the cylinders and raised the FEL so I could work on the part better, about shoulder height, made it easy to hold "C" part by myself and insert the blots and other parts.
    The "C" channel goes facing cup inward (mine had notches for a front grill guard they line with the notches in larger piece), the long flat spacer piece goes on bottom, the 2 smaller flap pieces go between the "C" channel and the crossmember there are notches on each end of the "C" channel to accommodate the tongue of the flap parts, there are 16 bolts that are the same and 4 different with smaller heads, those along with nuts on each go into the "C" channel where the 4 blot holes are in the bottom of the "C" channel, they are a tight fit almost think they are wrong size, I think they did that to make sure there is a resistance on them (I tightened them by hand, they are hard to turn, you can feel when they actually bottom out on the plates), the other 16 bolts with lock washer (tightened them with impact) and nuts go into the other holes. I put the "C" channel in and used a bolt on either side at each end to hold it left nuts loose, dropped one end down slid the flap piece between "C" part and crossmember tongue down, replaced bolts then did the same on the other end. Tighten all 16 then tighten the 4 last is what I did. YMMV
  10. #29
    New Member HereticWild's Avatar
    Join Date
    Jun 2012
    Posts
    17
    Armstrong, BC
    Kioti CK20 HST
    Quote Originally Posted by IslandTractor View Post
    I bought a new CK20HST in May 2012, the serial number starts with K so I assume it's a 2011 edition. It came with a KL120 Loader Pkg w/50" Bucket and Grille Guard (free loader deal). Serial Number for that starts with TA1009. How do I know if it's the newer version?
  11. #30
    Join Date
    Sep 2005
    Posts
    11,640
    Prudence Island, RI
    Quote Originally Posted by HereticWild View Post
    Is the torque tube (the connecting piece about three feet behind the bucket that holds the left and right side of the loader together) round and hollow or is it a closed box? Almost certainly you have the round tube version as the original version has not been manufactured for about five years now.
Similar Threads
  1. Kubota LA450 FEL Gland Nut Cracked
    By cytafex in forum Hydraulics
    Last Post: 06-03-2011, 05:28 PM
  2. Ford 1910 4x4, cracked FEL mount.
    By shadawick in forum Parts/Repairs
    Last Post: 10-08-2010, 10:30 AM
  3. BX22 FEL cracked
    By copperhead1967 in forum Kubota Owning/Operating
    Last Post: 05-28-2006, 05:37 PM
  4. B2150 w/ cracked FEL bucket
    By Stephen in forum Kubota Buying/Pricing
    Last Post: 01-03-2001, 03:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
