Results 11 to 16 of 16
10-09-2012, 09:09 PM #11Bronze Member
- Join Date
- Nov 2007
- Posts
- 84
- Location
- New Brunswick, Canada
- Tractor
- JD 755, Kioti DK40SE
10-09-2012, 09:30 PM #12
10-10-2012, 08:29 AM #13
10-10-2012, 10:07 AM #14Bronze Member
- Join Date
- Nov 2007
- Posts
- 84
- Location
- Tractor
Re: Block heater for cab tractors
I see what they did, and it's what I was thinking about too.
The cab heater return line is normally placed (at least on my tractor) where the heater is located on yours. By placing the heater where the return is normally placed they were able to l mount it on an angle. Clearly your tractor had enough slack in the heater hose to move it a couple inches down, hopefully mine has enough slack too.
Jason
10-10-2012, 01:08 PM #15
10-11-2012, 10:57 AM #16Bronze Member
- Join Date
- Nov 2007
- Posts
- 84
- Location
- Tractor
I checked my tractor last night and it should be possible to get enough slack to relocate the return port a couple inches further away.
My next question is has anyone ever drained the cooling system on a cab tractor? I'm concerned that if I drain the system will the heat exchanger in the cab also drain and will I have to deal with an air lock.
I suspect there must be a check valve in the system somewhere otherwise wouldn't the coolant flow out of the rad when you take the cap off?
I was thinking I would pinch both of the heater hoses before draining just to be sure.
Jason
Similar Threads
TC30 Block Heater stupid questions and Transmission Heater advice
By ksshooter in forum New Holland Owning/OperatingReplies: 7Last Post: 10-28-2011, 04:01 PM -
Diesel Fuel Heater or Block Heater?
By TroySD in forum Owning/OperatingReplies: 7Last Post: 09-02-2011, 08:09 PM -
How I start AIR COOLED tractors W/O Block Heater
By Bradlyk in forum Owning/OperatingReplies: 14Last Post: 01-02-2011, 09:43 PM -
GC2300/GC2310: block heater or recirculating antifreeze heater?
By FredWalter in forum Massey Ferguson Owning/OperatingReplies: 1Last Post: 02-28-2008, 03:13 PM -
Engine block heater / coolant heater & high-capacity alternator
By Phunge in forum John Deere Owning/OperatingReplies: 3Last Post: 10-30-2007, 11:49 AM
