Results 1 to 7 of 7
  1. #1
    Join Date
    Jun 2011
    Posts
    248
    Penobscot,Me
    07 Kioti DK45 SE HST/401 FEL
    Default even new oil can be dirty
    A while back, I think thread had something to do with the 50 hrs fluid changes, we got off track and and had a debate about filtering new oil. Today I emptied a new 1 gal container of hydraulic oil. I needed a shallow container to put under a filter I was changing so I cut the bottom off the oil container. I was surprized at the amount of sludge in the container bottom. I filter 5 gal and above containers now. I guess I may have to start filtering smaller containers.
    Attached Thumbnails Attached Thumbnails even new oil can be dirty-389-jpg
    Don
    Kioti DK45 SE HST/401 FEL, 7 ft landscape rake, 4 ft QA forks, 7' Fisher snowplow converted to QA, Satoh Bull 630D w/fel (being restored) JD 317, mower, tiller
  2. #2
    Elite Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,514
    Cumberland Plateau, TN
    Bobcat CT225
    Default Re: even new oil can be dirty
    That is a good example of why it is not advisable to pre-fill your filters when changing them, engine oil, hydraulic fluid, or fuel. They all contain some contaminat. If pre-filled it sends that stuff down stream to vital working components. On the other hand, I don't think it is necessary to filter your oils before putting into the engine or hydraulic system. The pump will suck it up, send it through the filter and stay there before it goes to any vital part of the system.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  3. #3
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Wow!
    looks like someone forgot to tighten filters in the processing plant or they had one blow out.
    I know all about working the graveyard shift in a processing plant for 10 years.
    Oops is a common word among operators.
    Tom
    2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
    1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
    United Steel Workers Union 12934
  4. #4
    Join Date
    Feb 2012
    Posts
    1,480
    Northern Michigan
    KIOTI DK50 HST
    Quote Originally Posted by seacap04 View Post
    The last batch of Rotella T that went into my truck looked like that. Filtered it and now I use Delvac. The delvac containers have been clean. And before you jump on me Murphy yes I always look!! CJ
    Kioti DK50HST Cab
    401 FEL
    Saws, 338xp,346xp mod,372xp mod, 390xp, Stihl combi 130 trimmer.
  5. #5
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Quote Originally Posted by CJONE View Post
    What the heck did I do now?
    Murph
  6. #6
    Join Date
    Feb 2012
    Posts
    1,480
    Northern Michigan
    KIOTI DK50 HST
    Quote Originally Posted by murphy1244 View Post
    Nothin I was just pokin at ya from our first discussion but I could not find my smiley face. [well I am computer handicapped!!]
    All Good.
    CJ
    Kioti DK50HST Cab
    401 FEL
  7. #7
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    All Good.
    CJ
    Remind me, what happened then?
    Murph
Similar Threads
  1. 2720 Oil Question - How dirty is your oil?
    By megaboz in forum John Deere Owning/Operating
    Last Post: 06-05-2011, 09:22 PM
  2. Oil & Fuel off road diesel cause dirty oil?
    By twodogs in forum Kubota Owning/Operating
    Last Post: 04-07-2007, 03:09 PM
  3. Dirty Oil Filter...Better than New One?
    By Henro in forum Oil, Fuel & Lubricants
    Last Post: 05-26-2004, 03:21 AM
  4. dirty oil
    By ealasimi in forum Oil, Fuel & Lubricants
    Last Post: 11-26-2003, 04:32 PM
  5. How dirty is your oil?
    By hazmat in forum New Holland Owning/Operating
    Last Post: 10-21-2002, 10:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
