Results 1 to 4 of 4
11-21-2012, 08:49 PM #1Silver Member
- Join Date
- Oct 2006
- Posts
- 115
- Location
- Kentucky
- Tractor
- Kioti DK35, Case 1190
Tach Cable Loose?
While changing oil I noticed a few shiny threads that looked out of place. I tried to tighthen up the knurled collar but it turned the entire cable...Before I made things worse, I thought I would post and see if anyone has experience with this cable. It is on a 2003 DK35.... Thanks in advance for any insight into this....
JeffandTamara
DK35 - Buhler FEL - Great Bend 851 BH
11-22-2012, 01:35 AM #2
Re: Tach Cable Loose?
Can you determine where the cable attaches on the other end?
This might help indicate what it is for, and what to do, if anything about the threads you show...2010 DK-40se/hst, Kioti KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower, 72" Ratchet Rake. HLA Series 2000 7' snowplow, Aquiline MPC Rear chains. Diamondplate aluminum canopy. Fit Rite Top-N Tilt hydraulics.
Scag Wildcat: Kawasaki 26HP.
Bunch of STIHL chainsaws
: 011, MS192T, MS200T, MS180C, MS230, MS270(Wood Boss), 038 Farmboss (1986 Anniversary edition).
11-22-2012, 08:34 AM #3Elite Member
- Join Date
- Feb 2002
- Posts
- 3,369
- Location
- western,pa.
- Tractor
- John Deere 850/Kioti DK 35 with top and tilt, kl1450 fel with quick detach bucket
It is the tachometer cable.
That nut is just stuck to the cable housing causing the entire cable to turn. It should turn free of the cable housing to tighten it up.
Spray a little penetrating oil on the nut to see if it will free up to turn.Vince,
Kioti DK 35/Rhino 85 backhoe
John Deere 850 72" MMM
Hustler Fastrak 54"
11-22-2012, 05:06 PM #4Silver Member
- Join Date
- Oct 2006
- Posts
- 115
- Location
- Kentucky
- Tractor
Thanks Vince, Sounds like a plan. I will soak her down and see what happens... I thought that might be the problem, but thought it would be a good idea to get a more experienced account...
JeffandTamara
Similar Threads
Tach Cable
By CCC in forum Ford Vintage TractorsReplies: 1Last Post: 04-22-2010, 05:57 PM -
tach cable
By fsteyer in forum Mitsubishi/SatohReplies: 1Last Post: 06-23-2006, 04:14 AM -
Tach drive cable
By Slamfire in forum Mitsubishi/SatohReplies: 3Last Post: 08-24-2005, 11:54 PM -
Tach cable
By 6795 in forum Mitsubishi/SatohReplies: 2Last Post: 02-25-2005, 12:49 AM -
Tach cable
By buppy69 in forum Massey Ferguson Owning/OperatingReplies: 3Last Post: 06-06-2002, 02:56 PM
