Page 5 of 6 FirstFirst ... 23456 LastLast
Results 41 to 50 of 54
  1. #41
    Join Date
    Feb 2012
    Posts
    660
    Northern Michigan
    KIOTI DK50 HST
    Default Re: Only front chains?
    Quote Originally Posted by npalen View Post
    This has probably been mentioned previously but it should be noted when changing tire sizes on a FWA, the change needs to be worked out as a percentage rather than simple addition. For example, adding 2" to rears of, say, 40" diameter results in a 5% change. (2 divided by 40) Adding that same 2" to the fronts of, say, 24" diameter would result in a change of approximately 8%. (2 divided by 24) The result of this scenario would be that the fronts will be "leading" the rears by much more than the design intent. The same result would occur when chaining the fronts and rears assuming that the chains increase the OD by the same amount front and rear. The front wheels would be trying to outrun the rear wheels resulting in more stress on the front drive. Not saying it would or would not be catastrophic over time.
    Thank you, Great info! CJ
    Kioti DK50HST Cab
    401 FEL
    Saws, 338xp,346xp mod,372xp mod, 390xp, Stihl combi 130 trimmer.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #42
    Join Date
    Feb 2012
    Posts
    660
    Northern Michigan
    KIOTI DK50 HST
    Quote Originally Posted by Coyote machine View Post
    If I were you I'd buy a pair of rear chains and use them. If after doing so you still see a need for fronts then go for it. You're going to slide sideways even with chains in some situations, unless you get a pair for around $1600 or more, with studs, like my dealer showed me in his catalog. That's for just the rear!!
    Just a FYI, I have not slid sideways with the V-Bars and I have a bad driveway. It is off camber and steep. I cannot climb it with the tractor in 2WD with snow on it and cannot plow uphill with out chains on at least the rear. The V-Bars really work well. CJ
    Kioti DK50HST Cab
    401 FEL
  4. #43
    Join Date
    Feb 2012
    Posts
    660
    Northern Michigan
    KIOTI DK50 HST
    Quote Originally Posted by Dingo Man View Post
    Sooo , let me ask this, would a high quality set of rears give my tractor enough grip in the rear as to prevent the front end from sliding sideways.
    No, the front will still slide. But from my experience a set of V-bars on the rear will let you run in 2WD and the front chains will not let the front slide unless you take too much weight off with the loader. In 2WD you have less wear and little chance of damage. CJ
    Kioti DK50HST Cab
    401 FEL
  5. #44
    Silver Member Dingo Man's Avatar
    Join Date
    Sep 2009
    Posts
    218
    Maine
    12' Kioti DK40SE HST
    Quote Originally Posted by CJONE View Post
    Yep, that sounds good. I will probably buy chains for all four. I will at least have them if needed. I will try using only 2WD as much as possible just to be on the safe side but I am still not buying the fact that placing chains on these tractors is going to some how ruin the running gear. Even with chains it seems there is going to be plenty of give and slippage, especially on snow and ice.
    12' DK40SE HST
    KL401 FEL, 72" Sundown Tiller, 72" Kodiak Rotary Cutter
  6. #45
    Join Date
    Feb 2012
    Posts
    660
    Northern Michigan
    KIOTI DK50 HST
    IMHO if it is done with a little common sence I don't believe you would hurt anything either. But that is in short supply anymore. I let a friend borrow my 25hp tractor/snowblower, I now have a fan with 3 bent blades and a hole through the side of the housing. I have ran it for 5 years with less damage than him using it twice! Some people can tear up a anvil then blame it on you. Getting blamed is what I try to avoid and err on the safe side when suggesting something to someone and I won't suggested something if I don't have personal experience with it. If you were closer I would let you try my front chains so you could see the difference. Thought about selling them but I know as soon as I do I will need them. CJ
    Kioti DK50HST Cab
    401 FEL
  7. #46
    Join Date
    Sep 2009
    Posts
    218
    Maine
    I again agree about the common sense. I have some friends I would never loan anything too because they are hard on equipment. I believe my snow removal around the house with chains will not over work this machine.
    My dealer advised me they would suggest either chains on just the rear or chains on all four, never chains on just the front. He stated to just put chains on it and run it, they have hundreds of customers up here using chains and having no problems with it.
    12' DK40SE HST
  8. #47
    Veteran Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    2,265
    Southern VT
    '10 Kioti DK 40se/hst
    I've checked all over the place for chains for my tractor and finally found what I am told will work best for my use.
    I'm going to get Aquiline mpc chains for just my rear tires for now. They allow for minimum clearance issues for my fenders, and R-4 Titan Heavy Duty Industrial Tractor Lug tires sized at 14.9 x 24
    I am coupling that with a HLA brand, lateral float, with crossover valve, 2000 Series 7' all steel plow, made in Canada. I considered a Sno-way plow with vertical float, crossover valve, and plastic moldboard; which is also a good choice for my tractor, but I want as little stress on my loader assembly as possible. Lateral float seems from an engineering standpoint to best accomplish this task. There is another forum on snow equipment use and it has tons of useful information and detailed videos by guys like 4shorts. I learned today from one of his recent videos that to keep from slipping on the front tires he drops his plow on the ground and then raises it slightly to keep the weight on the front tires, INSTEAD of on the loader. Seems like a no brainer, but it makes perfect sense, especially coming from a former heavy equipment operator and experienced snow tractor specific professional user.
    Here are links to the chain type I was referring to: Aquiline Tire Chains
    And to the HLA Plow: HLA Snow
    2010 DK-40se/hst, Kioti KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower, 72" Ratchet Rake. HLA Series 2000 7' snowplow, Aquiline MPC Rear chains. Diamondplate aluminum canopy. Fit Rite Top-N Tilt hydraulics.
    Scag Wildcat: Kawasaki 26HP.
    Bunch of STIHL chainsaws : 011, MS192T, MS200T, MS180C, MS230, MS270(Wood Boss), 038 Farmboss (1986 Anniversary edition).
  9. #48
    Gold Member landedakioti's Avatar
    Join Date
    Jul 2012
    Posts
    307
    lisbon falls,maine
    kioti dk40se hst
    Default
    These I got today do I put them on tried it on a hill that was a sheet of ice they worked great I never had to put it in 4 wheel drive.
  10. #49
    Join Date
    Jun 2011
    Posts
    198
    Penobscot,Me
    07 Kioti DK45 SE HST/401 FEL
    [QUOTE=landedakioti;3159179]These I got today do I put them on tried it on a hill that was a sheet of ice they worked great I never had to put it in 4 wheel drive.
    That's what I have and don't use unless I really need them. The mile and half on the road to my shop will knock you silly. Be careful because you will still slide sideways going across a hill. They are fantasic in mud.
    CM, know you will, but would really like to know what you think about the chains after you test them. Them look like my solution. Looks like they address packed snow and ice. Also side slip going across a hill.
    Don
    Kioti DK45 SE HST/401 FEL, 7 ft landscape rake, 4 ft QA forks, 7' Fisher snowplow converted to QA, Satoh Bull 630D w/fel (being restored) JD 317, mower, tiller
  11. #50
    Join Date
    Feb 2012
    Posts
    660
    Northern Michigan
    KIOTI DK50 HST
    Coyote, DO NOT get a Snoway plow with the lexan moldboard. I have broke at least 3 of them and just patched them with steel. The plow is good just a poor idea with the lexan.Only front chains?-tractor-020.jpgOnly front chains?-tractor-021.jpgOnly front chains?-tractor-023.jpg Included a few pics of my rear chains also. I finially figured out how to do it. [computer handicapped!] CJ
    Kioti DK50HST Cab
    401 FEL
Similar Threads
  1. Traction Chains up front
    By RayCo in forum Kubota Owning/Operating
    Last Post: 03-02-2011, 02:23 PM
  2. Chains Front chains on GC?
    By 75H2 in forum Massey Ferguson Owning/Operating
    Last Post: 02-18-2010, 01:20 PM
  3. Chains Front tire chains
    By PA-Woodchuck in forum Kubota Owning/Operating
    Last Post: 02-04-2009, 03:19 PM
  4. Chains front chains
    By loopyl in forum Kubota Owning/Operating
    Last Post: 12-23-2007, 09:27 PM
  5. Chains front chains
    By massdeere in forum John Deere Owning/Operating
    Last Post: 12-25-2005, 06:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
