Getting mad
Page 9 of 11 FirstFirst ... 67891011 LastLast
Results 81 to 90 of 101
  1. #81
    Gold Member landedakioti's Avatar
    Join Date
    Jul 2012
    Posts
    450
    vermont
    kubota L4060 hst
    Default
    So I put the new one in started right so I went over to pull out more wood . Then I shut the tractor off to use the chainsaw then loaded the wood in the bucket then went start and again nothing I had to take it a part to clean and put it back together to start the tractor. I 'm going to call the dealer to see when the update ignition switches are coming.
    Getting mad-image-2441344691-jpg
  2. #82
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Default Re: Getting mad
    I feel your pain Nate
    Murph
  3. #83
    Join Date
    Jul 2012
    Posts
    450
    vermont
    kubota L4060 hst
    Default
    Quote Originally Posted by murphy1244 View Post
    It sucks I'm getting tired of this problem kioti needs to man up and fix the issue.
  4. #84
    Veteran Member kiotiken's Avatar
    Join Date
    Aug 2011
    Posts
    2,497
    Dunrobin, Ont
    2012 Kioti DK45 HST Cab
    That's a real bummer. I can understand your frustration and I felt your pain with my CK30. Sometimes I think a machine is just cursed, no other way to explain it. I was very leary buying a second Kioti just to get out of a bad first experience with one, but with 85hrs on the clock of the DK45, not a single problem I didn't cause. Hopefully once you get the ignition sorted out you have the same experience. Have you priced out an ignition from CAT as was suggested?
  5. #85
    Member
    Join Date
    Nov 2012
    Posts
    37
    Northern,Nh
    kioti dk 40 hst,cub cadet 7265
    To Landed a Kioti,I don`t believe they would have a left over 2010 tractor when you bought your tractor but stranger things have happened.They wouldn`t have a leg to stand on if they misrepresented the year of the tractor because you have the contract with year of the tractor right on it and of course you have the manufacturers plate located somewhere on the frame with the build date right on it!
  6. #86
    Join Date
    Aug 2011
    Posts
    2,497
    Dunrobin, Ont
    Quote Originally Posted by pmaintman View Post
    Tractors don't have models years the same way cars do. There is simply a manufacturing date of the tractor. There is no difference between a 2010/11/12/13 DK 40 for instance. I'm not saying it doesn't matter, I'd want one built the same year I bought it, but you can't go back to them on model year.
  7. #87
    Silver Member Dingo Man's Avatar
    Join Date
    Sep 2009
    Posts
    225
    Maine
    12' Kioti DK40SE HST
    [QUOTE=Gil Case;3161417]To answer your question, I grew up not too far from where you are, on what today would be today be called a subsistence farm. In the 30's and 40's it was called "dirt poor".
    I am not questioning your (or your families) philanthropy nor your benevolence, just your veracity.
    You "jump ugly" pretty quick.[/QUOTE
    Wow that is some good talking out of both sides of the mouth.
    12' DK40SE HST
    KL401 FEL, 72" Sundown Tiller, 72" Kodiak Rotary Cutter, NAI 48" Root Grapple
  8. #88
    Veteran Member ritcheyvs's Avatar
    Join Date
    Nov 2011
    Posts
    1,589
    Kittrell, NC
    Kioti DK45S
    Quote Originally Posted by landedakioti View Post
    So I put the new one in started right so I went over to pull out more wood . Then I shut the tractor off to use the chainsaw then loaded the wood in the bucket then went start and again nothing I had to take it a part to clean and put it back together to start the tractor...
    lande ... there must be something else going on here other than just the switch. A new switch can't go bad in such a short time. Maybe juggling the wires to work on the switch restores a break in the wires, or something. A Diesel will run just fine regardless of the electrical system (except for the stop solenoid) so it's quite possible that the problem in your start system returned seconds after starting the engine.
    Scott: Kioti DK45S, KL451 loader, Phoenix M72S mower, Deere BB5072 Box Scraper, Fit Rite Hydro Top & Side Links; DIY Kioti knowledge site (in work): http://kioti.dyndns.org/
  9. #89
    Join Date
    Jul 2012
    Posts
    450
    vermont
    kubota L4060 hst
    Default
    Quote Originally Posted by ritcheyvs View Post
    When I opened up the new one the copper had greenish tint on it. I do think there is something else I talk to a dealer that are still waiting for the updated switches. When they get them from kioti they will come and install it and test everything else.
  10. #90
    Join Date
    Aug 2011
    Posts
    2,497
    Dunrobin, Ont
    Did they send you a new switch or an old one they took out of somebody elses tractor? That doesn't sound like a new part to me.
Similar Threads
  1. Buying Advice To many choices going mad
    By smalltown in forum John Deere Buying/Pricing
    Last Post: 04-01-2011, 12:10 PM
  2. Oil & Fuel GRRRRR :mad:
    By Bradlyk in forum Owning/Operating
    Last Post: 12-25-2010, 09:34 AM
  3. One mad snake is out there...
    By txdon in forum Rural Living
    Last Post: 07-03-2009, 10:59 PM
  4. mad
    By tjm in forum Kubota Owning/Operating
    Last Post: 12-01-2002, 12:41 AM
  5. MAD COW
    By CSAW in forum Related Topics
    Last Post: 01-26-2002, 03:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
