Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Member
    Join Date
    Dec 2010
    Posts
    47
    Bolingbrook,IL
    Kioti DK55
    Default Hydraulic Filter hard to get off!
    Trying to change the Hydraulic/transmission fluid on my DK35, I cant get the filter off. Poked a hole in the filter trying to get it off. Anybody have any suggestions?
  2. #2
    Join Date
    Jun 2004
    Posts
    1,088
    Armstrong, BC
    Kioti DK35 SE HST (2011)
    Default
    It's a common situation on a Kioti's first oil change. The filters are ridiculously tight. I used a 1/2" ratchet nylon strap wrench the first time. One of those chain filter wrenches would also work.
    They're fine once you get them off and reinstall as per Kioti's instructions. I wish they would follow their own instructions for the first install.
  3. #3
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,727
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: Hydraulic Filter hard to get off!
    Yes, it is.. on the first one I poked a hole thru it with 1/2 inch all thread and managed to turn it a bit.. BUT I would suggest you go buy a chain wrench and use that. Save your self the hassle.. They are put on by a 900 pound gorilla for some reason.. Don't put the replacement one on that tight!
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  4. #4
    Platinum Member Katahdin's Avatar
    Join Date
    Dec 2010
    Posts
    749
    Scarborough, ME
    Yanmar LX4500, Toro z420
    I just removed all the spin-on filters on my Yanmar with a large pair of channel lock pliers, maybe the same would work for you.
    Hydraulic Filter hard to get off!-channel_locks-jpg
  5. #5
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,072
    north idaho
    Kioti DK45SE hst cab
    i 3x the post about the adjustable filter wrench. The auto parts store sold me a real nice one that uses a standard 1/2" ratchet wrench to help in the removal. worked great. ill have to get a pic of it.
    heres a site selling it.
    you just insert your ratchet wrench and go at it.
    http://shop.advanceautoparts.com/web...80&ci_gpa=pla& ci_kw={keyword}&gclid=CNSbhKOZm7UCFYl_Qgodd1IAVg#
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  6. #6
    Member
    Join Date
    Dec 2010
    Posts
    47
    Bolingbrook,IL
    Kioti DK55
    Holy smokes! Broke the chain wrench! I poked a hole with a screw driver, almost broke it! I dont think I ever seen a filter this hard to get off. Crazy. Thanks all!
  7. #7
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    You may have to use a pound of black powder!
    Murph
  8. #8
    Join Date
    Jan 2011
    Posts
    7,072
    north idaho
    dont get into an arm wrestling match with this Korean filter installer hehe
    currently own
  9. #9
    Elite Member whistlepig's Avatar
    Join Date
    Jan 2009
    Posts
    4,267
    Preble County, Ohio
    Kubota B7800 with FEL
    Quote Originally Posted by grsthegreat View Post
    Buy Performance Tools Strap Filter Wrench W173C at Advance Auto Parts ci_kw={keyword}&gclid=CNSbhKOZm7UCFYl_Qgodd1IAVg#
    These strap wrenches don't look like much but the one I have owned for several years has never seen a filter it couldn't handle. I have had it crush some filters getting them off but it always gets them off.
    I used to do the Hokey Pokey but I turned myself around.
  10. #10
    Join Date
    Jan 2011
    Posts
    7,072
    north idaho
    ill admit i wasnt too impressed at first. but after i broke my home depot strap wrench, i got this one out and it took the filter right off. no issues at all. im sold now
    currently own
Similar Threads
  1. Oil & Fuel Hard to get to Oil Filter on 1526 Massey Ferguson
    By radrock in forum Massey Ferguson Owning/Operating
    Last Post: 03-09-2013, 12:04 AM
  2. Replies: 5
    Last Post: 10-30-2012, 02:42 AM
  3. Oil Filter used for Hydraulic filter?
    By Noodlez914 in forum Hydraulics
    Last Post: 10-21-2012, 03:25 PM
  4. Replies: 3
    Last Post: 04-10-2012, 09:30 AM
  5. What's hard on hydraulic systems?
    By Bob_Trevithick in forum John Deere Owning/Operating
    Last Post: 12-27-2001, 10:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
