DK-40 Added aux fuses/terminal block for extra lights
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
  1. #11
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,411
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    Default Re: DK-40 Added aux fuses/terminal block for extra lights
    DK-40 Added aux fuses/terminal block for extra lights-img_2256-jpg
    Left front 7" Blazer halogen, 55W, with blue tint lens.
    DK-40 Added aux fuses/terminal block for extra lights-img_2257-jpg
    Left rear 3x5" halogen, 55W Baja light, under canopy.
    DK-40 Added aux fuses/terminal block for extra lights-img_2258-jpg
    Left rear, orange rotator, and strobe above.
    DK-40 Added aux fuses/terminal block for extra lights-img_2259-jpg
    Right rear, orange rotator, and strobe.
    DK-40 Added aux fuses/terminal block for extra lights-img_2260-jpg
    Left rear different angle.
    DK-40 Added aux fuses/terminal block for extra lights-img_2261-jpg
    Aux halogen work light, (off factory spare fuse/wire). Also, Kolpin Chainsaw holder, works great! and SMV sign.
    DK-40 Added aux fuses/terminal block for extra lights-img_2262-jpg
    Light switch, (lighted green when off, red when in use), above metal plate shown, left side rollbar.
    DK-40 Added aux fuses/terminal block for extra lights-img_2263-jpg
    Factory toolbox behind seat, with receptacles cut in for wiring harnesses.
    DK-40 Added aux fuses/terminal block for extra lights-img_2264-jpg
    Toobox left rear view.
    DK-40 Added aux fuses/terminal block for extra lights-img_2265-jpg
    Fuses, 15A, built inline in harnesses, relays for harnesses, (one each pair of lights), and cut in box for wire entry.
    DK-40 Added aux fuses/terminal block for extra lights-img_2266-jpg
    Index finger pointing to toolbox harness and velcro wire straps. like using velcro until final version to be able to do up, then undo if needed without wasting numerous cable ties.
    DK-40 Added aux fuses/terminal block for extra lights-img_2267-jpg
    Wire harness into right side of box.
    DK-40 Added aux fuses/terminal block for extra lights-img_2268-jpg
    All rear lights ON except aux.
    DK-40 Added aux fuses/terminal block for extra lights-img_2269-jpg
    Same as above.
    DK-40 Added aux fuses/terminal block for extra lights-img_2270-jpg
    Rears, different view angle.
    DK-40 Added aux fuses/terminal block for extra lights-img_2271-jpg
    Rears.
    DK-40 Added aux fuses/terminal block for extra lights-img_2272-jpg
    Rears.
    DK-40 Added aux fuses/terminal block for extra lights-img_2273-jpg
    Fronts and headlights- note headlights uselessly dim.
    DK-40 Added aux fuses/terminal block for extra lights-img_2274-jpg
    Fronts and headlights different angle- shows contrast to headlights.
    The wires are protected by fuses, as mentioned above, and I did add an inline fuse holder at the scotch lock where the factory hot wire feeds the added circuit. The fuse holder holds a 30 amp fuse to protect all downstream wiring and lights. To date I have run everything at once, headlights and all auxillary lights, strobe, rotating orange light, etc. with ZERO problems, no blown fuses, etc.
    I use the lights for many things, but especially night time plowing. The work light is obvious for it's use and can be rotated as needed to direct light where I need it and it can be adjusted up or down for similar outcomes. The switch is temporary, I could not locate the switch I planned to use.
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  2. #12
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    what the heck is all this for? I see you put captions on the pictures so we know what your showing and why.
    Murph
  3. #13
    Join Date
    May 2009
    Posts
    7,411
    Southern VT
    Quote Originally Posted by murphy1244 View Post
    Why does it have to be for anything in particular? Have you taken over for my mom?
    See the post above yours- it will have a detailed explanation shortly, for those who asked me to show them details of my work.
  4. #14
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    If I was your mother I would have left you at the curb. I see you did a edit job.
    Murph
  5. #15
    Platinum Member Buckgnarly's Avatar
    Join Date
    May 2012
    Posts
    529
    West topsham VT
    Kioti DS3510
    Am I understanding that you ran an entire fuse block for all that with a Scotch Lock? Just me, but not sure I'd trust that running all that. How many amps are you pulling through that Scoth lock with that?
  6. #16
    Join Date
    May 2009
    Posts
    7,411
    Southern VT
    So what is YOUR purpose in being here? Yeah, figures that would be your view of children, hope you don't have any.
    I AM editing my own post- you have a problem with that too?
    You done anything that contributes to TBN's overall betterment recently? Highly doubt it.
    Don't have anything positive to say- then leave.
    Speaking of editing: seems you edited your above post to add: "I see you put captions on the pictures so we know what your showing and why."
    I SAID I was not finished and would be posting more details as I got to them, and I have done so.
    Any questions?
    Last edited by Coyote machine; 03-17-2013 at 03:26 PM. Reason: To further clarify my process for the very dense among us
  7. #17
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Quote Originally Posted by Coyote machine View Post
    Your funny,
    Murph
  8. #18
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Your funny,
    Murph
  9. #19
    Join Date
    May 2009
    Posts
    7,411
    Southern VT
    Your funny,
    Duplicate post, with editing- you're slipping.
    BTW, it's: you're funny
  10. #20
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Well I did not want to make you cry, Yes you are funny!
    Murph
Similar Threads
  1. intelpenel lights blown fuses
    By unadilla in forum Parts/Repairs
    Last Post: 11-15-2007, 09:08 PM
  2. Added an extra cooling Fan
    By kludge in forum Power Trac
    Last Post: 09-19-2005, 03:12 PM
  3. White terminal block under dash
    By moweraxle in forum Kubota Owning/Operating
    Last Post: 01-09-2005, 02:52 PM
  4. LIGHTS BLOW FUSES
    By HERKYEC130 in forum Customization
    Last Post: 12-29-2003, 11:12 AM
  5. Added Aux lights to my 6000
    By Slippy in forum Mahindra Owning/Operating
    Last Post: 07-22-2003, 11:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
