DK35 Axle oil.(Dumb Question)
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Member
    Join Date
    Dec 2010
    Posts
    47
    Bolingbrook,IL
    Kioti DK55
    Default Re: DK35 Axle oil.(Dumb Question)
    Thanks all for the help. I have a 2003-2004 DK35. I did get the manual, but it is not very good.
    I took some pics,
    This is the left side. Same as the other side.
    DK35 Axle oil.(Dumb Question)-20130310_120636-jpg
    This is under the axle (Center)
    DK35 Axle oil.(Dumb Question)-20130310_120818-jpg
    Lower unit (not sure what its called)
    DK35 Axle oil.(Dumb Question)-20130310_120849-jpg
    Not sure what this large bolt does
    DK35 Axle oil.(Dumb Question)-20130310_120721-1-jpg
    The sight glasses look very dirty. I cant tell the level of oil.
  2. #12
    Veteran Member kiotiken's Avatar
    Join Date
    Aug 2011
    Posts
    2,497
    Dunrobin, Ont
    2012 Kioti DK45 HST Cab
    My dealer always includes the 50 hr service , so I didn't do it myself, but I was there and took notes when they did the service on my CK30. According to what he told me, you can't overfill as long as it's on flat ground because the oil will seep out an overflow port. I'm assuming that would be the check/fill plug.
  3. #13
    Join Date
    Jun 2004
    Posts
    1,093
    Armstrong, BC
    Kioti DK35 SE HST (2011)
    It's been 2 years since I changed the front axle oil, so my recollection is a little vague. However, I think I removed all the three large fill plugs: one on the top of the right axle, and two near the top of the bevel gear housings. I also removed the plug containing the site glass facing rearward on the left axle.
    Then drained the oil by removing the small plugs at the bottom of the two bevel gear housings. After draining, I replaced the drain plugs and filled by the large plug on the top of the right axle. I may have also put some oil in the plugs at the top of the bevel gear housings, but I don't think so.
    I left the sight glass plug out and filled slowly until I saw oil starting to come from the sight glass plug hole. Then replaced the sight glass plug, and topped it up so the ball was in the middle of the sight glass.
    The last thing I did was replace the three large fill plugs.
    I probably added more oil one or two times later(after operating the tractor) to bring the ball into the sight glass center.
    SirRobinHood: the new DK SE's don't have the drain plug at centre of the axle.
    I'm due for the 400 hr service(actually 4 hrs overdue). I'll likely do the hydraulic and engine oil and filters soon, but will wait until it is warmer to do the front axle--likely in a couple of weeks.
  4. #14
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,446
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    Pulling the sight glass plug sounds like a good idea, otherwise one can spend a lot of time trying to get to almost full enough. By removing the sight glass plug it allows you to know when you're close and then top off after re-installing it. I like that idea a lot! It also lets one clean the sight glass to help keep an eye on the level in the axle.
    Thanks, KCO - good one
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  5. #15
    Member
    Join Date
    Dec 2010
    Posts
    47
    Bolingbrook,IL
    Kioti DK55
    Ok so I pull the lower plugs left and right on the bevel housing and center plug under axle. Drain oil. Pull sight glass off, open fill plug on top of axle and fill until the oil comes out of sight glass holes. Put sight glass plugs in and continue to fill until ball is center. You fill on only one side of axle correct? This should fill the whole axle housing (Both sides)? This will be about 2 gallons of oil?
  6. #16
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Yes that will fill both sides, my DK is 1.9.
    Murph
  7. #17
    Join Date
    May 2009
    Posts
    7,446
    Southern VT
    Quote Originally Posted by sirrobinhood View Post
    Yes, good summary. (Only one sight glass, clean it while it's out.) Fill till ball in center of red circle, then drive it and recheck in case of air bubbles, etc., make sure all plugs are snug and no leaks. Done.
  8. #18
    Platinum Member o2batsea's Avatar
    Join Date
    Nov 2008
    Posts
    515
    Maryland
    Kioti DK45C 2005
    Default
    I take the top caps off the axle pivot housing. This gives me a nice big hole to pour oil in. Takes very little time. Caps have a o ring seal, so don't get dirt in there, use a paper towel to clean before reassembly.
    Practicing the ancient oriental art of ren-ching.
  9. #19
    Join Date
    Jun 2004
    Posts
    1,093
    Armstrong, BC
    It has warmed up so I did the 400 hour service yesterday.
    It was 5 C (41 F) in the morning. I travelled to cut wood with a neighbour so the tractor was well warmed up by noon, when I changed all the fluids. The air temp was 10 C (50 F) then, and warmed to 15 C (59 F) shortly after.
    I don't know what the front axle oil temp would be, but it flowed like corn syrup. It took almost 2 hours to completely drain.
    Seeing this, I warmed the two 5 liter jugs of gear oil by placing them in hot water in the kitchen sink (fortunately my wife is away for a few days). I changed the hot water a few times while I did other servicing and waited for the front axles to drain. The heating worked great with the oil pouring like motor oil.
Similar Threads
  1. DK35 oil question
    By sirrobinhood in forum Kioti Owning/Operating
    Last Post: 01-27-2013, 09:22 AM
  2. Woods estate 60 LRC dumb question or dumb design?
    By donn12 in forum Attachments
    Last Post: 09-20-2009, 03:39 PM
  3. Branson 4020 oil dipstick dumb question
    By ronT in forum Century & Branson
    Last Post: 07-14-2005, 11:46 PM
  4. 3130 front axle oil question??
    By billj74 in forum Kubota Owning/Operating
    Last Post: 05-31-2005, 01:38 PM
  5. kioti DK35 engine oil
    By jb112454 in forum Kioti Owning/Operating
    Last Post: 11-19-2001, 09:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
