Results 1 to 8 of 8
03-14-2013, 08:15 PM #1
Missing bolt??
As I was cleaning some snow off my tractor this week I noticed one of the bolts that hold the cylinder and zerk in place was missing. Had to snowmobile to my tractor and didn't have a wrench to take another off for size comparison. Does anyone know the size and length of these??
03-14-2013, 09:27 PM #2
Re: Missing bolt??
Assuming you have a KL401, the parts site (OEM Parts ) says:
6 01133-51016 Hex Head Cap Screw, 10mm x 16mm $2.03
7 04613-50240 Stop Ring, E Type $1.00Scott
Kioti DK45S, KL451 loader, Howse 601S cutter, Phoenix M72S mower
03-14-2013, 09:30 PM #3
Re: Missing bolt??
I have lost 3-4 of these over the past few years...for some reason even with lock washers they fall out. Now i just keep occasionally checking them when greasing. I ended up picking up 8 of them at Fasteners Inc. there the 10mm fine thread style . 16mm as stated above. grade 8.8
at Fasteners there less than 0.25 each.currently own
2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
Quick Attach 79" loader mount snowblower & rear powerpack
Quick Attach 84" Snow Blade
Quick Attach 42" pallet forks
03-15-2013, 09:51 PM #4
03-15-2013, 10:14 PM #5
Re: Missing bolt??
I check them about every other time I grease, or 20 hours. I havent lost any, but one was nearly half way out once.
James K0UA
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
03-15-2013, 10:26 PM #6
Re: Missing bolt??
If these work lose, you may have play between the pin and the hole (in the piece it's bolted to) that allows movement. Or maybe you just use your loader more than me.
Scott
03-16-2013, 02:31 AM #7Platinum Member
- Join Date
- Mar 2013
- Posts
- 538
- Location
- Eugene, Oregon
- Tractor
- Toro D200, Ford 1715, International 884,
Re: Missing bolt??
Are there nuts too?
Do you use lock nuts?
What about using thread lock? The strongest (red?)
Do you have access to both sides of the bolt? You could also peen the end, or add two lock nuts.
I got it.
instead of such bright and shiny bolts, you just need a little RUST
03-16-2013, 12:00 PM #8
Re: Missing bolt??
currently own
Similar Threads
1971 MF 135 rebuild problem - missing bolt
By jeffsur in forum Massey Ferguson Classic/VintageReplies: 2Last Post: 01-28-2010, 09:19 AM -
Grapple Bodozer Bolt-On Bucket Claw/ATI Bolt-On Grapple
By Engine66 in forum AttachmentsReplies: 1Last Post: 11-06-2007, 12:57 PM -
I need a bolt on toothbar for a bucket w/HD bolt on cutting edge
By OakHillFarmer in forum AttachmentsReplies: 5Last Post: 08-15-2007, 03:55 PM -
Missing Wheel Bolt on BX23
By Allen2 in forum Kubota Owning/OperatingReplies: 2Last Post: 05-23-2005, 06:43 PM -
Bolt missing from sub frame FEL attach. for 4100
By ducati996 in forum John Deere Owning/OperatingReplies: 7Last Post: 08-08-2003, 01:46 PM
