Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Elite Member
    Join Date
    Apr 2012
    Posts
    4,183
    Northern Ontario, Canada
    2012 Kioti CK27HST w/cab
    Default Re: Anybody with a CK27HST
    Anybody with a CK27HST-img_0001-jpg
    So what does the 'A' and the 'B' do? The 'N' I am going to assume is neutral.
  2. #12
    Platinum Member rmorey's Avatar
    Join Date
    Nov 2012
    Posts
    840
    Eastern Ontario
    Kioti DK40SE HST Cab, Mechron 2200
    The "A" position, lets fluid out the top jack and returns on the lower jack. "B" reverses it. So if you have an implement attached, such as a rotary chute on a snowblower, "A" turns the chute left and "B" turns it right.
    Rick
  3. #13
    Elite Member
    Join Date
    Apr 2012
    Posts
    4,183
    Thank you.
  4. #14
    Bronze Member Notlaker's Avatar
    Join Date
    Mar 2012
    Posts
    58
    Niagara-on-the-Lake, Ontario
    Kioti CK30HST
    Default
    Is it possible that your 'D' is actually a 'B' with the middle of the 'B' worn off?
  5. #15
    Elite Member
    Join Date
    Apr 2012
    Posts
    4,183
    That was a typo on my part. I just fixed it.
  6. #16
    Elite Member Mousefield's Avatar
    Join Date
    Aug 2008
    Posts
    2,618
    Qualicum Beach on Vancouver Island, BC. Canada
    Sold 2008 CK35 HST
    Quote Originally Posted by Looking4new View Post
    No, do NOT assume N is neutral.
    On my tractor N still supplies hydraulic pressure
  7. #17
    Elite Member
    Join Date
    Apr 2012
    Posts
    4,183
    Quote Originally Posted by Mousefield View Post
    Is 'N' the position that supplies pressure to the loader?
  8. #18
    Join Date
    Aug 2008
    Posts
    2,618
    Sold 2008 CK35 HST
    No. I just came back from grading my road with the boxblade on the 3pt hitch. The lever in N postion is what controls the 3pt hydralics, in A it controls the backhoe when I have it on. I have to move the lever between A or N, it basically redirects the hydraulic to each area as needed for the (A) backhoe or (N) 3pt. You should check in your manual in case my setup is different from yours. As far as I know this lever has nothing to do with the front loader, if I'm wrong I'm sure someone will correct me.
  9. #19
    Join Date
    Nov 2012
    Posts
    840
    Eastern Ontario
    The a/n/b switch is strictly used to control the rear remote operation. the big red knob controls the 3pt hitch. If you add a second rear remote, you will get another switch, but it will have c/n/d on it to differentiate it from the other. ab controls one set and cd controls the other.
    The loader is controlled by the remotes located on the right hand side of the loader frame in front of you.
    Rick
  10. #20
    Elite Member
    Join Date
    Apr 2012
    Posts
    4,183
    Thanks people. As you can tell, I've never had rear remotes on a tractor before. the way I figure it, it is way easier and cheaper to ask on here than to do and break something.
Similar Threads
  1. New Kioti CK27HST
    By whitet101 in forum Owning/Operating
    Last Post: 02-05-2013, 08:57 PM
  2. Ck27hst, r4's and tiller.
    By pickeringchris in forum Kioti Owning/Operating
    Last Post: 01-21-2012, 03:01 PM
  3. If the CT225 is the same as the CK27HST...
    By Lockport in forum Bobcat Tractors
    Last Post: 05-15-2011, 01:11 PM
  4. CK27HST vs CT225
    By Lockport in forum Kioti Owning/Operating
    Last Post: 05-10-2011, 10:58 AM
  5. Price Check CK27HST Price Check
    By kidkioti in forum Kioti Buying/Pricing
    Last Post: 02-16-2010, 02:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
