Results 11 to 20 of 25
03-21-2013, 09:44 PM #11
03-21-2013, 11:08 PM #12
- Join Date
- Jan 2011
- Posts
- 708
- Location
- Westmoreland County PA
- Tractor
- Fords
Re: FEL paint peeling
This is a common problem with a lot of equipment. What we see in those photos is a result of:
1. Improper metal prep
2. Failure to use primer
3. Use of inferior paint products (most likely alkyd enamel).
With the epoxies and polyurethanes available today, I have a hard time trying to come up with reasons why so many manufacturers continue to use paint technologies of the past. The obvious reason is cost. If I was given the option to spend $1000 more on a $30000 tractor to ensure that it doesn't rust away, it would be a no-brainer.
03-22-2013, 12:03 AM #13
- Join Date
- May 2009
- Posts
- 7,411
- Location
- Southern VT
- Tractor
- '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
WOW! KK, I think they painted those cylinders in the South Korean Sea, literally UNDERWATER.
Bogus! That tractor needs two new cylinders, now. I wouldn't bother with doing anything with them but getting your dealer to replace them. Rust as bad as that and as extensive as it is will be hard if not impossible to fix and last.
Powdercoating might work if they were taken apart and stripped down and reassembled after- heat would cook the seals, as suggested by Gary. Not worth the effort and that is just another reason it's under warranty- MANUFACTURING DEFECT!!
Oh, I almost forgot- it's just a tractor, man, so no worries
Call dealer, send him the later pics- get new cylinders.
Sorry for your trouble- it sux...2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
Bunch of STIHLchainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
03-22-2013, 07:34 AM #14
- Join Date
- Aug 2011
- Posts
- 2,497
- Location
- Dunrobin, Ont
- Tractor
- 2012 Kioti DK45 HST Cab
Well, new cylinders was my first thought as well but the problem isn't limited to the cylinders alone. I tried to post about 8 pics last night put it didn't work. The pics I didn't retry showed the end of the loader arms close to the pins on either side doing the same thing. I did call my dealer and sent him the link to this post (hey Jim), so I'll wait to see what can be done about it.
From the parts that are affected and the pattern of the rust on the front of the FEL, it really seems like the tractor was sitting waiting for paint and somebody drove by on a cart and splashed it with dirty water or something. Standing in front of the tractor, the right side is much worse than the left side but they're both rusting in a splash pattern.
03-22-2013, 08:20 AM #15
- Join Date
- Jun 2009
- Posts
- 28,152
- Location
- Branson, Mo.
- Tractor
- Kioti DK35se Hydrostat
That is what I was thinking too, that there was something on the metal that was painted over. It would be interesting to take your pocket knife to the edges of one of those blister areas and pop some more paint off of the edge of the blister and look at the metal and see if it is clean or if it too is rusted already.. In other words, is it just a splash or is the problem more widespread under the paint. And if you are not able to pop the paint off at all, perhaps that would tell us that it is adhered properly, and lend more credence to the splash contamination theory.
James K0UAJames K0UA
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
03-22-2013, 08:39 AM #16
- Join Date
- Aug 2011
- Posts
- 2,497
- Location
- Dunrobin, Ont
- Tractor
The thought of it not being a splash type issue scares me, not sure I'm ready to face that possibility. I'll let my dealer have a look at it first, but it's a good idea, I guess I want to know if the entire machine's going to look like that after a year. Dealing with paint issues under warranty doesn't seem like an easy thing to do. I've never had the experience, but have read a lot of bad stories of people who have.
03-22-2013, 11:09 AM #17
- Join Date
- Jun 2004
- Posts
- 1,092
- Location
- Armstrong, BC
- Tractor
- Kioti DK35 SE HST (2011)
03-22-2013, 01:20 PM #18
Mine looks fine after one winter other than scrapes and such in the bucket from snow/gravel.
BTW, do you guys re-paint your bucket's every year?
BTW2 - hey KCO - Hi from another Kioti owner in Armstron BC!
03-22-2013, 01:35 PM #19
- Join Date
- Jun 2004
- Posts
- 1,092
- Location
- Armstrong, BC
- Tractor
03-22-2013, 01:51 PM #20
- Join Date
- Aug 2011
- Posts
- 2,497
- Location
- Dunrobin, Ont
- Tractor
Hey now, that's almost name calling!!!!!
I'm a little surprised how well the bucket has held up (paint wise). I've hauled lots of gravel, done lots of soil and a bit of digging. I now have 100 hours and it'll be one year old sometime in April. That's less than I put on my CK 30 the first year I had it (135) but not that much less, and it's bucket didn't have much paint left on it.
Similar Threads
Paint peeling from grills
By animalharley03 in forum Kioti Owning/OperatingReplies: 10Last Post: 12-19-2010, 08:03 PM -
Paint peeling
By Bdavis in forum Mahindra Owning/OperatingReplies: 5Last Post: 05-16-2010, 07:41 PM -
Paint peeling off fender of new 3320
By ilmoman in forum John Deere Owning/OperatingReplies: 16Last Post: 02-28-2010, 10:39 PM -
TC40D Paint Peeling
By djradz in forum New Holland Owning/OperatingReplies: 5Last Post: 03-02-2001, 05:41 PM -
Mowing Mower Peeling Paint
By DaleW in forum Kubota Owning/OperatingReplies: 8Last Post: 09-25-2000, 12:39 PM
