CK20/KB2465 Backhoe Question
Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Apr 2013
    Posts
    9
    Ontario
    Kioti CK20
    Default CK20/KB2465 Backhoe Question
    Debating the purchase of a KB2465 for my CK20. Was wondering about the lifting capacity of the backhoe for hoisting things out of the back of a pickup, for example, or for lifting rocks, etc. None of the specs seem to address this. Anyone have any idea?
  2. #2
    Platinum Member rimshot's Avatar
    Join Date
    Jan 2008
    Posts
    659
    Michigan
    Kioti CK2510 HST
    Default Re: CK20/KB2465 Backhoe Question
    I really can't answer your question but the information is covered in many ways. Such things as break out and different measures are availble in the owner's manual. Have been to the Kioti web site? They used to show some figures. Kioti Tractors
    I would repeat this purchase if I need to.
    rim
    CK2510 HST , Kioti front snow blower,backhoe, FEL, Pallet forks and 5' box blade
  3. #3
    Super Member mguitas's Avatar
    Join Date
    Aug 2011
    Posts
    7,921
    Schuylkill County Pennsylvania
    Massey Ferguson 1423 Hydrostat
    Quote Originally Posted by Striker3636 View Post
    Maybe about 400 pounds, my hoe can lift 385 from 3 feet to the ground.
    Massey 1423, 1462 loader, wallenstein Ranch ho gx620, with subframe mount. Deere 710c
  4. #4
    Veteran Member kiotiken's Avatar
    Join Date
    Aug 2011
    Posts
    2,497
    Dunrobin, Ont
    2012 Kioti DK45 HST Cab
    To many variables come into play to give numbers. Certain functions have a lot more strength in certain positions than others. I could raise the dipper stick long after I ran out of strength to raise the boom and it all depend on how high you're lifting from and how out the whole thing is.
    My guess would be that you can't lift much out of the bed of a pickup truck. I would guess you'd be able to lift more using a small pole attached to the loader.
  5. #5
    Silver Member Phil48's Avatar
    Join Date
    Mar 2012
    Posts
    145
    Eastern TownShip
    CK20 HST
    Hello Striker!
    Excellent backhoe, but not really design for lifting... The real strength is all about the curling effect of the bucket. For example, at one point, I try to lift just a couple of inches a generator set in a pick up so that we could slide a piece of plywood between the liner and the steel frame. I use a chain and the scooping force of the bucket to lift it... The hydraulic responded perfectly, but the only things that got off the ground were the front wheels! For lifting with my CK20HST there's nothing the FEL.
    Phil
    Attached Thumbnails Attached Thumbnails CK20/KB2465 Backhoe Question-backhoe-curling-jpg
    Phil
  6. #6
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,961
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I agree with others here, too much variables to determine lifting force. Depending on the reach, it could be anywhere from 100 pounds (or less) when fully extended to several hundred or even a thousand pounds. The dipper has more strength dragging too you than extending away which is what you would do if lifting. Best lifting is with the curl of the bucket which is where the most strength is. Lifting items from a PU truck would require a lot of extension to get the height needed and that would severely limit your lift capacity. I think the hoe in curl would lift 1000 pounds but with it extended out to reach whatever is in the truck bed, it is going to lift the front wheels off the ground first. I suppose you could put in a load of dirt or other ballast in the FEL to help hold it down, but again, a backhoe isn't designed for lifting a lot of weight, its designed to push down with lots of force as in digging. If you look at all the cylinders, the most force is directed at extending the cylinder. The diameter of the cylinder rod has to be deducted from the hydraulic force exerted when retracting the cylinder so if you have a 3" cylinder with a 1" rod you would have about 7 square inches of area on the cylinder for pushing down but only about 6.2 square inches picking up. On a 2200 PSI hydraulic system that would be approximately 15,500 pounds of force exerted down vs 13,600 lifting up plus you have to add in the lifting of the back hoes weight also. That equates to about 80% lift capacity vs dig capacity.
    One other thing to consider is that you would need to weld on a lifting hook to the back of the bucket which would be the weak side for lifting. You could put it inside the bucket but it would mean that the chain or strap would then be resting on the bucket edge which isn't a good idea.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  7. #7
    New Member
    Join Date
    Apr 2013
    Posts
    9
    Ontario
    Kioti CK20
    Thanks everyone. The hoe is on order along with a hydraulic thumb. Wanted a ripper tooth too but already blew the budget.
Similar Threads
  1. QUESTION: ck20 - how strong & capable is the Kioti Backhoe?
    By TSO in forum Kioti Owning/Operating
    Last Post: 07-27-2012, 01:09 PM
  2. Backhoe KB2465 storage cradle
    By JonKioti in forum Kioti Owning/Operating
    Last Post: 09-12-2011, 09:53 AM
  3. Selling a Woods BH6000, buying a KB2465
    Last Post: 06-21-2009, 05:06 PM
  4. Backhoe My CK20 now with backhoe
    By Rollerskate in forum Kioti Owning/Operating
    Last Post: 09-26-2003, 03:56 PM
  5. Backhoe CK20 Loader Backhoe?
    By GaryG in forum Kioti Owning/Operating
    Last Post: 04-21-2003, 03:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
