Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 44
  1. #11
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,192
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Default Re: rodent chewed hole in fuel tank DK45HST.....death to all rodents
    Quote Originally Posted by pilotman View Post
    polyethylene type tanks can be welded. Use welding rod to match tank, heat with heavy duty soldering gun. the tank will be good as new.
    I did this with a taillight a few months back and it worked very well.
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  2. #12
    Elite Member MotorSeven's Avatar
    Join Date
    Aug 2005
    Posts
    4,033
    NE TENN (Hancock Co)
    Kioti DK40SE Hydro
    I've always wanted to try the plastic welding kit at HF. So far I have use JB weld with outstanding success to seal the cracks up on the inside of the DK fuel bowl, so I think it would also work on the fuel tank.
    BTW....get a barn cat or three
    2008 KIOTI DK40Se Hydro
    1978 Sling Blade/wood handle
  3. #13
    Join Date
    Jan 2012
    Posts
    81
    Mountaindale, Oregon
    Allis Chalmers ACD19, ACG; Kubota BX2200 FEL, B2710 FEL, L355SS FEL; Cat D47U, Ford 4600SU FEL
    JB weld works for me. Repaired my 270 gal fuel tank with it also.
    Dennis
    Quote Originally Posted by JimRB View Post
    I have used a JB Weld gas tank repair kit but it was for a metal tank. BlueMagic
  4. #14
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,760
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I repaired the cracked fuel tank on my LS tractor that had 4 nuts imbedded in the bottom of the tank to attach a skid plate (PP engineering ). I removed the tank, acetone cleaned it, then used a wire wheel on my 4.5" grinder to rough up the areas and applied enough pressure to kind of V groove the cracks. Acetone cleaned it again letting it soak a bit to soften the plastic then applied JB weld generously to cover the cracks, nut and holes and leave about an 1/8" build up. After it dried, I reinstalled the tank and it has been in service for 2 years and still no sign of a leak. LS replace the tank for me under warranty so I still have the new tank in the box it came in just waiting for the old tank to start leaking. SO FAR SO GOOD.
    I think the idea of putting in a screw might be good especially if you put the JB Weld over the screw to seal and reinforce it. The screw will give the JB Weld something to hold on to also. Unfortunately to do this, you are going to have to remove the tank as all this has to be done in the flat position.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  5. #15
    Gold Member mj007's Avatar
    Join Date
    Mar 2010
    Posts
    252
    Western Colorado
    2009 Kioti CK20S HST, 1937 Oliver 60 RC, 4 Case VA Series tractors.
    get a couple of barn cats and don't feed 'em
    2009 CK20S HST - KIOTI Loader & backhoe, backblade, FEL/3-point forklift attachment, 5-ft. brushhog
    Other tractors: 4 CASE VA Series, 1 Oliver 60.
  6. #16
    Platinum Member saracenas's Avatar
    Join Date
    Oct 2010
    Posts
    967
    Lithuania, EU
    Present: 2003 Kubota M9000 DTF. Sold: 1985 Kubota L2202
    Is it a 21st century tractor "feature" - to be able be eaten by rats? One day you may find no fender or no hood, or no harness, because that stuff is simply ... consumed. Hate such a prospect.
  7. #17
    Epic Contributor IslandTractor's Avatar
    Join Date
    Sep 2005
    Posts
    21,120
    Prudence Island, RI
    2007 Kioti DK40se HST, Woods BH
    Quote Originally Posted by MotorSeven View Post
    The HF kit works but the heating iron fitting is made of crap steel so if you apply any pressure it will bend and break. Just go slowly and wait for the "shoe" fitting to fully heat up before trying to use it.
  8. #18
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,067
    north idaho
    Kioti DK45SE hst cab
    Quote Originally Posted by saracenas View Post
    yup....a biodegradable tractor
    i like having the plastic tank, as ive had to deal with rusted steel tanks before. but never saw this coming.
    im going to try the epoxy paste seal first off....see if it holds. I got a tube of JB Weld 15 min epoxy.
    The rat/squirrel already roughened up the surface alot. Ill use some brake cleaner first and try the patch.
    Ill probably order a new tank just to have on hand, as i dont want to be down during the winter due to a hole in tank.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  9. #19
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,609
    Murray, KY
    1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel
    That is a funny story from this angle.
    Never would have expected that in a million years.
  10. #20
    Join Date
    Sep 2005
    Posts
    21,120
    Prudence Island, RI
    Default
    Quote Originally Posted by grsthegreat View Post
    You may be shocked at the cost of a new tank. These are not standard or generic tanks.
    If it were me, I'd make a JB Weld repair and watch it carefully this summer. Some of those epoxy repairs are essentially life long.
Similar Threads
  1. Replies: 14
    Last Post: 09-04-2017, 11:52 PM
  2. Dirt in Fuel Lines - Fuel Tank Needs Cleaning
    By noggles in forum TYM Owning/Operating
    Last Post: 06-29-2013, 04:57 PM
  3. Got the fuel container spout out of tractor fuel tank
    By JOHNTHOMAS in forum Kubota Owning/Operating
    Last Post: 05-29-2012, 07:43 AM
  4. Sealing hole in plastic fuel tank????
    By weedpharma in forum Rural Living
    Last Post: 02-11-2010, 12:23 PM
  5. BX2200 Chewed itself up, scared to death
    By botalvr in forum Kubota Owning/Operating
    Last Post: 05-24-2006, 07:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
