Results 1 to 10 of 10
  1. #1
    Platinum Member dourobob's Avatar
    Join Date
    Mar 2002
    Posts
    670
    Just West of Buckhorn, Ontario, Canada
    Wheel Horse 522xi
    Default Hydraulic leak
    Been away from this forum for a while. We sold our farm and have moved to a place where I no longer need my DK45SE HST. I was just moving the last few heavy pieces of statuary before getting ready advertise the tractor for sale and I noticed a dark spot on the ground underneath the area on the right side of the rear axle.
    Unfortunately, I left all my KIOTI manuals at the old farm with the intention of getting them later, but things have gone sour with the new owners and I may not be successful recovering the manuals.
    I will try to get some photos to posts in the next day or two but am hoping some one has run into this before, can give me some advise and direction on what to look for first and that this is a quick and easy fix.Tha
    Thanks for any ideas.
    Bob
    2009 KIOTI DK 45 SE HST, MID West Box Blade 20-72, 5 foot Bush hog rotary mower, 76" Meteor Snowblower
  2. #2
    Join Date
    Jun 2011
    Posts
    232
    Penobscot,Me
    07 Kioti DK45 SE HST/401 FEL
    Default Re: Hydraulic leak
    The way I trace leaks is I clean all traces of oil from lowest point to highest point. This usually tells me what is leaking.
    Don
    Kioti DK45 SE HST/401 FEL, 7 ft landscape rake, 4 ft QA forks, 7' Fisher snowplow converted to QA, Satoh Bull 630D w/fel (being restored) JD 317, mower, tiller
  3. #3
    Join Date
    Mar 2002
    Posts
    670
    Wheel Horse 522xi
    Thanks seacap
    I had a few minutes today and was able to crawl under and behind the tractor with your "find the highest point" advice in mind.
    Now my challenge is to describe it accurately so instead, I also took a few pics which I hope will save 1,000s of words.
    I wasn't able to see any oil higher than this but ....
    Any advice or suggestions appreciated
    -leak2-jpg -leak-1-jpg
    Thanks Bob
  4. #4
    Join Date
    Jun 2011
    Posts
    232
    Penobscot,Me
    I guess I will crawl under mine tomorrow and see if I have the same valve. Off the top of my head I would say a worn O-ring. Good photos.
    Don
  5. #5
    Join Date
    Mar 2002
    Posts
    670
    Wheel Horse 522xi
    Worn "O" ring sounds like it should be easily fixable. Tractor is still under warranty for another few months but the dealer I bought from is closed and the next closest is about 90 minutes away. I have not contacted the new dealer yet and I don't have a trailer to float the tractor, so I will have to see if I can negotiate a "house call" with one of their mechanics.
    Bob
  6. #6
    Silver Member krazsk's Avatar
    Join Date
    Oct 2009
    Posts
    199
    Bobcat CT225, McCormick X10.50H
    I hate to state something wrong, or what may be obviously wrong, but is that the cover on the auxiliary (remote) hydraulic unit? If so, take those nuts off and look at the o-rings before you pay someone to come out 90 miles. If that's what it is, it isn't magic, I had it off when I added another hydraulic remote. There's no parts that will come flying or springs or anything. --- If that's the part. Good Luck
  7. #7
    Join Date
    Mar 2002
    Posts
    670
    Wheel Horse 522xi
    I believe that is the cover for the auxillary hydraulic remote as seem on page 10-80 in the service manual. I did manage to find an electronic copy of that)
    Having never done any work on this area before, I have some questions:
    1. do I just remove the cover (by undoing the two nuts)?
    2. what should I see when the cover is off?
    3. any gaskets or other things to look for?
    4. are the O-rings held on by that cover?
    5. are they standard sized O-rings or do I need to get them from a KIOTI dealer?
    6. is there a "While I have it apart I should also check ......" suggestion?
    Don't have any problem trying to do this but I don't want to immobilize the tractor right now if I can limp along for a few weeks by just topping up the hydro fluid.
    Bob
  8. #8
    Join Date
    Jun 2011
    Posts
    232
    Penobscot,Me
    Haven't had to take mine apart so I have no words of wisdom to pass to you. Good luck.
    Don
  9. #9
    Join Date
    Mar 2002
    Posts
    670
    Wheel Horse 522xi
    Default Auxiliary Hydraulic Remote
    Thanks seacap
    I could really use some advice from someone who knows what I will find when I start taking things apart.
    HELP!
  10. #10
    Join Date
    Oct 2009
    Posts
    199
    Default
    Yeah it's just a cover I don't know how to describe the function but there are just holes or passageways for the oil flow. There are just some o rings sealing around those hole/ passageways. I believe the o rings are actually in a slot on the remote hydraulic unit and the cover is machined smooth. Then you will just need to match the crushed or pinched oring and replace it. Much better than a service call. Some others tell you to replace them all but I haven't been burned bad yet reusing o rings that still look good, not deformed. Go for it and thank me tomorrow. If you've said your prayers and always eaten your vitamins you might be lucky enough to just put the orings in place - if one isn't seated right. Good luck.
Similar Threads
  1. Hydraulic leak
    By trillium33 in forum John Deere Owning/Operating
    Last Post: 11-03-2011, 10:08 PM
  2. Hydraulic Leak
    By Erik Lundberg in forum Hydraulics
    Last Post: 02-20-2010, 09:31 PM
  3. Help with a hydraulic leak!!!
    By carolinadozer in forum John Deere Owning/Operating
    Last Post: 09-03-2009, 09:16 AM
  4. Hydraulic oil leak??
    By vtkubota in forum Owning/Operating
    Last Post: 02-16-2007, 01:58 PM
  5. Hydraulic Leak and hot hydraulic lines on JM 254
    By Anonymous Poster in forum Chinese Tractors
    Last Post: 07-08-2003, 03:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
