Tried to Change Hydro Filters Today Whoa...Tight!
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Platinum Member rmorey's Avatar
    Join Date
    Nov 2012
    Posts
    840
    Eastern Ontario
    Kioti DK40SE HST Cab, Mechron 2200
    Default Tried to Change Hydro Filters Today Whoa...Tight!
    51 hours, time to do the "50".
    Drained the engine oil, wiped off the drain caps and reinstalled. Filter wrench on ol filter and...slowly it begins to turn. Good, Smear some oil on the new filter rubber and spin it on, hand tight, then a little twist with the wrench for good measure. Wipe up the drips.
    Now for the hydro filters. HST filter on one side, Hydraulic filter on the other. No problem....HA! Tried everything, nothing doing. They must have put the filters on before painting the block. Called the dealer, he suggested "grunting" LOL! After his chuckling ended, he then suggested large channel locks. What do you suggest?
    Rick
  2. #2
    Platinum Member ozley's Avatar
    Join Date
    Mar 2005
    Posts
    676
    TN
    LS U5030C
    Default
    A big screwdriver popped thru the filter or chain wrench.
    LS U5030C, International McCormick B-414 Gas
  3. #3
    Join Date
    Nov 2012
    Posts
    840
    Eastern Ontario
    Default Re: Tried to Change Hydro Filters Today Whoa...Tight!
    Quote Originally Posted by ozley View Post
    Thought of the screwdriver, but if it didn't work, I'm "screwed". (no pun intended)
    Rick
  4. #4
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    There are plenty of threads on this but a strap wrench will do
    Murph
  5. #5
    Platinum Member DutchHenryBrown's Avatar
    Join Date
    Aug 2009
    Posts
    907
    Tombstone, AT
    Mahindra 5010
    On my 50 hour service I ended up using 2 filter wrenchs one up near the block and the other at the outer edge of the filter. It worked but it was not pretty.
  6. #6
    Super Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    Strap wrench
    A good one that you can put a 1/2" strongarm on though. I love my Snapon A91E A91E, Wrench, Oil Filter, Strap, (1" to 6" filter diameter)
  7. #7
    Join Date
    Mar 2005
    Posts
    1,870
    Erie, Pennsylvania
    Kioti CK30HST
    I too had to use a strap wrench with a one inch rubber belt. I kept it close to the end, trying not to crush the filter just in case it didn't work. After the first time, they come off normally.
    Vic
    2004 Kioti CK30hst, KL130 fel, KB2375 bh
  8. #8
    New Member
    Join Date
    Aug 2008
    Posts
    10
    Pittsburgh PA
    Kioti DK55, Case International 245
    Try the channelok 209 9-1/2" or channelok 212 4-1/4" filter wrench depending on your filter size. Removed the hyrdo filter on my Dk55 .
    Tried to Change Hydro Filters Today Whoa...Tight!-wrench-jpg
  9. #9
    Super Member
    Join Date
    Dec 2007
    Posts
    5,665
    Canada
    Ford 3930
    Vice grips with chain.
    I have VGs built that way, but regular VG+chain works too. Wrap as much chain as you can around the filter, to distribute the load, clamp tight with VG, then give 'er.
    Don't get too carried away tightening filters with wrenches, as that can distort the base gasket on some filters. I always just hand tighten and (knock wood) never have an issue.
    I mentioned chain/VG first because you may have them lying around. I also like the type that you use with a ratchet on the end of the filter, like this one, and also the style that has two C shaped arms - I have both.
    Adjustable Oil Filter Wrench | Princess Auto
    Let us know what works.
    Rgds, D.
  10. #10
    Gold Member mj007's Avatar
    Join Date
    Mar 2010
    Posts
    255
    Western Colorado
    2009 Kioti CK20S HST, 1937 Oliver 60 RC, 4 Case VA Series tractors.
    What the dealer said - mine are my weapon of choice
    2009 CK20S HST - KIOTI Loader & backhoe, backblade, FEL/3-point forklift attachment, 5-ft. brushhog
    Other tractors: 4 CASE VA Series, 1 Oliver 60.
Similar Threads
  1. changing both hydro filters
    By RAYJAY in forum LS Tractor Owning/Operating
    Last Post: 06-23-2013, 09:27 PM
  2. B2X20 how many hydro filters?
    By donn12 in forum Kubota Owning/Operating
    Last Post: 07-10-2010, 05:49 PM
  3. oil/hydro filters
    By loopyl in forum Owning/Operating
    Last Post: 05-21-2007, 11:59 AM
  4. Now Hydro Filter Not On Tight Enough!
    By HarleyBob in forum Kubota Owning/Operating
    Last Post: 01-09-2004, 03:54 PM
  5. hydro filters
    By cchoate in forum Owning/Operating
    Last Post: 06-21-2002, 10:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
