Power beyond question?
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    New Member
    Join Date
    Nov 2013
    Posts
    16
    Brewton,Alabama
    Kioti ck30
    Default Power beyond question?
    Trying to install rear remotes on a ck30 Kioti. Tractor has front loader wanted to know if this has power beyond.in the pic upper left above further left hose has hex plug is this the power beyond for adding on. In the owners manual it say from pump port. Any help would be much appreciated thanks in advance.
    Attached Thumbnails Attached Thumbnails Power beyond question?-image-jpg
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Power beyond question?
    PB ports are usually on the side of the valve.
    Show some more pics of the side where the OUT port is.
    How many hose are on the FEL valve now?
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    New Member
    Join Date
    Nov 2013
    Posts
    16
    Brewton,Alabama
    Kioti ck30
    Thanks for the reply JJ. Here are a few more pics,I will call the north toward the front tires,south rear tires,east to ward step and west under tractor.
    Attached Thumbnails Attached Thumbnails Power beyond question?-image-jpg   Power beyond question?-image-jpg   Power beyond question?-image-jpg   Power beyond question?-image-jpg   Power beyond question?-image-jpg
  4. #4
    New Member
    Join Date
    Nov 2013
    Posts
    16
    Brewton,Alabama
    Kioti ck30
    1st pic is the north,2nd is south,3rd is west and 4th is east. The close up is west side the line coming out goes to the rear lift. I believe that the hex plug you see is the power beyond but I'm not sure.
  5. #5
    New Member
    Join Date
    Nov 2013
    Posts
    16
    Brewton,Alabama
    Kioti ck30
    JJ this is a pic from Manuel. The other is what I'm trying to do. Once again thanks for the reply.
  6. #6
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,433
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    So you want to do this with all after market stuff? The OEM units are very reasonably priced IMO.
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  7. #7
    New Member
    Join Date
    Nov 2013
    Posts
    16
    Brewton,Alabama
    Kioti ck30
    Mt. I'm not sure would like to price both ways wanted add top link for my mom and brother who both like to work the tractor. Moms getting older and brother is in a wheel chair thought might allow them to operate equipment better
  8. #8
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Where is the banjo line from T1 going?
    The other port with the banjo fitting, where is it going.
    You can test the OUT and PB ports like this.
    The OUT port will only have flow when a cyl is moving.
    The PB line will have fluid flowing all the time except when the cyl are using all the pump flow.
    You may have PB installed, and if so, just add your new remote is series with the 3pt input.
    If you are going to do T-N-T, you might want float on one or more spools.
    J.J.
    Git er done.
  9. #9
    New Member
    Join Date
    Nov 2013
    Posts
    16
    Brewton,Alabama
    Kioti ck30
    Thanks for the info fellas it raining here today and I start a
    Shutdown for the next 2 weeks I'll be back to tell what I found and for more advice once again thanks very much to all. Roll Tide Roll!
  10. #10
    New Member
    Join Date
    Nov 2013
    Posts
    16
    Brewton,Alabama
    Kioti ck30
    Ok guys I'm ready to order my parts just one question.How do I find out what length cylinder to buy for top link. I have a ck30 kioti any recommendations on top link cylinder. (Bore size-stroke length) thanks in advance.
    Roll Tide Roll!
Similar Threads
  1. Power Beyond question
    By MR_NC in forum John Deere Owning/Operating
    Last Post: 02-24-2013, 12:17 PM
  2. Another Power Beyond Question
    By daBear in forum Hydraulics
    Last Post: 03-25-2011, 03:01 PM
  3. Power Beyond Question
    By gsdavis1 in forum Hydraulics
    Last Post: 03-19-2011, 07:27 AM
  4. Power Beyond Question
    By papafoxtrot in forum Kubota Owning/Operating
    Last Post: 10-05-2006, 07:20 AM
  5. Power Beyond question
    By CVHoss in forum John Deere Owning/Operating
    Last Post: 03-31-2004, 09:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
