Everything Attachments Box Blade?
   / Everything Attachments Box Blade? #1
ritcheyvs
Kittrell, NC
Kioti DK45S
I have a DK45S but no implements except a mower and rotary cutter. I need to maintain some dirt trails that get rutted and high-centered with continued use. I also need to do occasional grading and minor earth moving. I am considering a box blade as well as a land leveler but the box blade seems less expensive and more versatile. My mowers are 72 inch and my back tires are almost 72 inches across.
Questions: Is the box blade the right first implement to get? If so, how wide should it be? Can anyone comment on the quality and value of the Everything Attachments box blades or recommend another brand/model?
Thanks.
   / Everything Attachments Box Blade? #2
Thanks.
I have a DK45 SE and the first implement I got was a box blade. I have a 72" mower as well. My use sounds similar to yours, but soil conditions may be quite different. Mine is mostly used for grading trails that are surfaced with crushed stone.
I ordered the 72" but ended up with a 66" because the wait would have been long for the wider blade. I am now glad I got the narrower blade, it is easier to maneuver and very nearly as wide as the tires. (Close enough) I made some modifications to mine, there is a thread at Kioti DK45SE box blade/carry-all/trailer hitch/counterweight/top n tilt VIDEO
I don't know anything about the Everythingattachments blade except to say that they seem well-respected by most people whose comments I have seen.
   / Everything Attachments Box Blade? #3
I purchased a 78" BB from EA for my DK40. I wanted something wider than my tires as I was grading our road with a decent drop off at the edge in spots and I wanted to keep the tires away from the edge. The only problem is that I didn't order it in time and it showed up a few days after the ground froze last fall. :( So I am now waiting until after the spring mud season to be over before I can use it.
   / Everything Attachments Box Blade? #4
I have a 72" EA prototype boxblade with the scarifiers mounted behind the beam.
That is one tough BB. It has done everything that I have asked it to with out any
problems. My outside tire width is 68" and I have no problems with the overhang.
Mine was made before they made them Cat1/Cat2 clevis hitches. They sold them
as prototypes. I would buy EA BackBlades again if I were starting over...
Tom
   / Everything Attachments Box Blade? #5
Thanks.
This or the equivalent is what I have and would get again. Other than hydraulic actuated rippers, it's hard to beat putting all the rippers down with a single pull of a lever, :cool:. Besides the unit simply being heavy duty. ;)
   / Everything Attachments Box Blade? #6
   / Everything Attachments Box Blade? #7
I bought a new BB with the second tractor DK40HST and love the box blade. It has the "clevis" style attachment which is stronger. Mine just had a sticker on it showing the model. I think my dealer said they are made in Illinois. This is the only picture I have of it.
   / Everything Attachments Box Blade? #8
I have an EA 72" box blade and am very satisfied with it. Very rugged construction
and works well with my Bobcat CT335 tractor.
   / Everything Attachments Box Blade? #9
I have a 96" EA box blade and also like it a lot, no problems and works great for snow too!
   / Everything Attachments Box Blade? #10
First, how do you plan to use the box blade, do you already have projects planned? What type of soil/dirt will you be working? I don't have an EA box blade, but I do have their HD lift type disc harrows and they work great, are high quality, and heavy. Weight is your friend with a box blade, a heavy box will do a lot more than a light one. For my purposes I went with a Dirt Dog 72" rollover blade @ 800 + lbs. It has been a great tool and done all that I have asked of it for several years now. Box blades come in all sizes and types and you should narrow your search by defining primary use before committing to a particular box.
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
Deere 333G (A53317)
Deere 333G (A53317)
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
