Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Join Date
    Mar 2005
    Posts
    1,843
    Erie, Pennsylvania
    Kioti CK30HST
    Default Re: Rotary cutter size question for a CK20s HST
    As LD1 mentioned, slower with a 5 or faster with a 4. Another thought to add. If you ever decide to sell the cutter, a 5 probably will sell faster. Also, if you ever decide on a bigger tractor, a 5 will fit well and you won't need another cutter.
    Vic
    2004 Kioti CK30hst, KL130 fel, KB2375 bh
  2. #12
    Join Date
    Oct 2013
    Posts
    130
    Leon County, FL
    Kioti CK20 HST
    Quote Originally Posted by Pooter View Post
    I will be mostly cutting field brush no yard cutting .. I was told that I needed to get a cutter at least as wide as the back wheels of the tractor if not I would be pushing down field grass making it harder to cut .. A 4 footer would be a little short of that .. And a 5 footer is a little more than a 22 hp ..17at the pto should pull from what I have been told .. Each dealer tells me something different .. Thanks Jeff
    If the cutter is wider than the tires to keep from pushing down the grass, then it would have to be a mid mount mower, cause anything you pull behind is going to be cutting what you have already driven over with both front and rear wheels..
    Rancho
  3. #13
    New Member Pooter's Avatar
    Join Date
    Apr 2014
    Posts
    20
    Kentucky
    Kioti CK20s HST
    Quote Originally Posted by Ranchofla View Post
    Rancho
    True .. I was just repeating what a salesman had told me Saturday about how I need to make sure to get a cutter wider than the back tires .. I was thinking the same thing when he said that~u had already ran over the field grass to get to where the cutter could cut it .
  4. #14
    Silver Member Hill Billy Bob's Avatar
    Join Date
    Aug 2010
    Posts
    147
    Western NY
    2011 Kioti CK30, 2005 Cub Cadet LT1050
    I pulled a 5' Bush Hog Razorback with my kubota B-8200 for 24 years. (19 HP gross...maybe 16 PTO) Used for mowing pastures, and hay field in fall, so I wouldn't have snow 2' deep laying there all winter. Grass height probably 18" or so most years. Have mowed that same field when the hay went uncut. Grass was higher than the hood of the Kubota, couldn't use full width of mower that year...took a while, lots of stops to clean grill...but got it done.
    Sold the tractor a few years ago, 2000+ hours on it, still ran like new, used no oil, and not a single leak anywhere on tractor (engine, trans, axles). Still have the Bush Hog, still works fine.
    Your Kioti would have no trouble handling a mower of that size.....all that is needed is a bit of common sense...HB Bob
    Rotary cutter size question for a CK20s HST-000_0348-jpg
    Forgot to mention, I never ran tractor/mower at the rated 2600rpm...always mowed at 2100 or so... Actual power being developed/used would be under the advertised HP, at this engine speed
  5. #15
    Join Date
    Apr 2014
    Posts
    20
    Kentucky
    Kioti CK20s HST
    Thanks, To bob and everyone that replied ... Purchased the Ck20 HST yesterday .. Will be Delivered Monday .. Had the 50hr service,loader hooks added and two Kioti hats thrown in the deal for $12.600 .. Thanks for your comments it really helps ..
  6. #16
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    17,911
    Central Ohio
    Kubota MX5100
    MAnd I cant even get a hat for $12.600
    All kidding aside, sounds like a nice deal. Make sure to post some pics monday when it arrives.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  7. #17
    Join Date
    Oct 2013
    Posts
    130
    Leon County, FL
    Kioti CK20 HST
    Congrats, you can now update your profile to say you have a Kioti!!
    Rancho..CK20HST
  8. #18
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,620
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    cool, post pics when it's all ready to play!
    souNdguy
    sent from my NOKIA LUMIA
  9. #19
    Join Date
    Apr 2014
    Posts
    20
    Kentucky
    Kioti CK20s HST
    Will do ..here's a pic of my 12 year old nephew giving it a test run . Rotary cutter size question for a CK20s HST-image-jpg
  10. #20
    Join Date
    Apr 2014
    Posts
    20
    Kentucky
    Kioti CK20s HST
    Where is a good place to pick up a 54 "rotary cutter .. Not having much luck locating one .
Similar Threads
  1. CK20S HST power question
    By thekidb in forum Kioti Owning/Operating
    Last Post: 06-06-2013, 03:51 PM
  2. Replies: 4
    Last Post: 07-26-2012, 10:11 AM
  3. What size rotary cutter?
    By SMOKEEATERFF in forum Attachments
    Last Post: 02-21-2012, 01:52 PM
  4. Rotary Cutter What size rotary cutter
    By mike194 in forum Attachments
    Last Post: 03-09-2008, 10:51 AM
  5. rotary cutter size?
    By Gamemaster in forum Kubota Owning/Operating
    Last Post: 03-22-2005, 10:42 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
