ritcheyvs
I plan to install my new Perry (same as Wells?) steel canopy, probably tomorrow, so I thought I'd check for any tips or hints before the main event. The canopy looks very nice but it did not include installation instructions so I thought I'd ask here.
My plan is to mount the brackets on the ROPS with the tops of the brackets level with the top of the ROPS, the top U-bolt snug, and the bottom U-bolt somewhat lose. The lose bottom U-bolt will allow the brackets to cant inward slightly to provide more clearance between the brackets and the inside of the angle iron frame on the actual canopy. Then I plan to get a neighbor's help to hoist the canopy into place and for him to help hold the front end (and wiggle as required) while I start the four bolts that faten the canopy frame to the ROPS brackets. I think the first and last bolt may be tricky. I Also saved a length of 2x4 to place between the canopy and tractor floor to hold up the front end of the canopy (in case we need a break). After I get the canopy securely mounted to the brackets, I'll see if I can lower it any by sliding the U-bolts down the ROPS (maybe an inch?). I have limited clearance under my lean-to so I'd like to mount the canopy as low as possible.
That's my plan but I know some of you have actually done this job on similar (maybe identical?) canopies. So I'm soliciting any advice. Thanks.
Scott
Scott
