frozen ignition key switch
   / frozen ignition key switch #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
I washed my tractor last week-end (trading). Seems like I got some water in the key ignition tumbler. It keeps freezing. I can't pull it in a heated area. Any way to de-ice this?
Would pouring alcohol in the key slot dry it out and stop the freezing?
   / frozen ignition key switch #2
Hair dryer?
   / frozen ignition key switch #3
Hair dryer or heat gun if it is within extension cord reach, possibly a propane torch if it isn't, and the flame is kept well away from any plastic to avoid blistering. Get the ice melted enough to get the key in, run it to a work area where you can blow out the water with an air hose and dose it with WD-40 to displace any stubborn moisture still in there.
   / frozen ignition key switch #4
yes. You can get small aerosol cans of lock deicer made just for that. Check your local autoparts store.
   / frozen ignition key switch #6
Maybe try lock deicer?
   / frozen ignition key switch #7
Mine was froze today dumped some menthol hydrate on it and few secs. late I was good to go.
   / frozen ignition key switch #9
Heat the key up. Insert into ignition switch. Key should melt the ice. Repeat.
Then pound the lock de-icer to it.
After you get the switch thawed out and hopefully dry, then get some graphite and put that to it.
   / frozen ignition key switch #10
If you can find a snowmobile key cover, it'll prevent those kinds of incident. Since then no more problem for me.
2015 Ford Escape SUV (A55853)
2015 Ford Escape...
UNUSED FUTURE XKH39 39" HYD 4N1 BUCKET (A57193)
UNUSED FUTURE...
2023 JOHN DEERE 325G SKID STEER (A52707)
2023 JOHN DEERE...
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
10' CONTAINER (A57193)
2018 ASV RT30 Forestry Posi-Track Compact Track Loader Skid Steer (A55851)
2018 ASV RT30...
